2018 Specialized S-Works Turbo Levo (Medium): £6500
Bimba
Birmingham
Bike Year: 2018
Manufacturer: Specialized
Model: S-Works Turbo Levo (Medium)
Asking Price: £6500 (open to sensible offers)
Description: Full Specification
New in May 2018 (Replacement for faulty first bike I bought in December 2017)
Specialized Carbon S-Works TURBO LEVO FSR 2018 6FATTIE/29 (Medium)
Collection from West Midlands
Complete with charger & all manuals
Bike has never been de restricted !
2Bliss Tyres - Done
Data tag - Can be transferred
Warranty - 12 months left
Frame warranty- life time
  • Frame - S-Works FACT 11m carbon, 6Fattie/29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post IR routing, 148mm spacing, fully sealed cartridge bearings, 135mm of travel
  • Fork - Öhlins RXF 36, 29/6Fattie, Twin-Tube design, air spring w/ adjustable 3rd chamber, adjustable high and low speed compression, adjustable rebound, 15x110mm thru-axle, 51mm offset, 150mm of travel
  • Shock - RockShox Monarch RT3, Rx Trail Tune, AUTOSAG, rebound and 3-position compression adjust, 197x48mm
  • Number of Gears - 11
  • Shifters - SRAM XX1, 11-speed
  • Chainset - Custom alloy crankarms
  • Chainrings - Forged steel, 32T
  • Cassette - SRAM XG1199, XD, 11-speed, 10-42t
  • Chain - SRAM XX1, 11-speed w/ PowerLink
  • Rear Derailleur - SRAM XX1, 11-speed
  • Bottom Bracket - Integrated with motor
  • Pedals - Not Included
  • Rims - Roval Traverse SL 27.5, hookless carbon, 38mm inner width, 24/28h, tubeless ready, hand-built
  • Front Hub - Specialized, sealed cartridge bearings, 15x110mm spacing, 24h
  • Rear Hub - Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
  • Front Tyre - Butcher, GRID casing, Gripton compound, 2Bliss Ready, 27.5 x 2.8"
  • Rear Tyre - Butcher, GRID casing, Gripton compound, 2Bliss Ready, 27.5 x 2.8"
  • Front Brake - SRAM Code RSC, hydraulic disc, 200mm
  • Rear Brake - SRAM Code RSC, hydraulic disc, 200mm
  • Brake Levers - SRAM Code RSC
  • Handlebars - Specialized Trail, FACT carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 31.8mm
  • Grips - Specialized Sip Grip, half-waffle, XS/S: regular thickness, M/XL: XL thickness
  • Stem - Syntace F109, 6-degree rise, 31.8mm clamp
  • Saddle - Body Geometry Henge Expert, hollow Ti rails, 143mm
  • Seatpost - Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm, M/L/XL: 125mm of travel
  • Post Clamp - Specialized Alloy 34.9mm, Ti bolt
    672K
