Michy Baker
Bike / Product Year: 2017
Manufacturer: Specialised
Model: Levo FSR Comp 6Fattie Medium Ladies 2017 (Small Men’s)
Asking Price: 2200.00
Description: I’m selling my Mint Specialised Levo as I have upgraded as I loved this one so much! Dont see many in this colour, Matt black with fluorescent yellow!
It’s classed as a ladies but would be ok for a small men’s (my husband borrows it!)
Healthy Battery 95%
Service regularly (by Hubby)
Hope 36T front chain ring
Mint condition, link below to full spec on Specialised website
EXTRAS!!!
I will include the Garmin Blue tooth which means you don’t have to use the buttons on the frame to adjust speed.
We have made it tubeless
Collection Bognor
07920 204202
SPECIFICATION
FRAME Specialized M5 Premium Aluminum, Trail Geometry, integrated down tube battery, enclosed internal cable and Command Post IR routing, 148mm spacing, fully sealed cartridge bearings, 140mm of travel
FORK RockShox Yari RC 29/27.5+, Solo Air spring, adjustable compression and rebound, 15x110mm Maxle Ultimate thru-axle, 51mm offset, 140mm travel
REAR SHOCK FOX FLOAT Performance, Rx Trail Tune, AUTOSAG, DPS damper, rebound and 3-position compression adjust, 197x47.6mm
FRONT HUB Specialized disc, alloy, sealed cartridge bearings, 110x15mm thru-axle, 24h
REAR HUB Specialized disc, alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES DT Swiss Industry, stainless
INNER TUBES 650bx2.3"/3.0", 40mm Presta valve
FRONT TYRE Purgatory, GRID casing, 650bx3.0", 60TPI, Aramid folding bead, 2Bliss Ready
REAR TYRE Purgatory, GRID casing, 650bx3.0", 60TPI, Aramid folding bead, 2Bliss Ready
CRANKSET Custom alloy crankarms
CHAINRINGS 32T
SHIFT LEVERS SRAM GX, 11-speed, trigger
REAR DERAILLEUR SRAM GX, long cage, 11-speed
CASSETTE SRAM XG-1150, 11-speed, 10-42t
CHAIN SRAM PCX1, 11-speed w/PowerLink
FRONT BRAKE SRAM Guide R, hydraulic disc, metallic pads, Guide S4 4-piston caliper, 200mm rotor
REAR BRAKE SRAM Guide R, hydraulic disc, metallic pads, Guide S4 4-piston caliper, 200mm rotor
HANDLEBARS Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 750mm width
GRIPS Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM Specialized Trail, 3D forged alloy, 4-bolt, 6-degree rise
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Command Post IRcc, 12 position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm, M/L/XL: 125mm travel
SEAT BINDER Alloy, 34.9mm
MOTOR Custom & exclusive for Specialized, Trail tuned, 250 W
UI/REMOTE Integrated Trail display, 10-LED battery display, Mission Control iOS/Android App
BATTERY Custom LEVO battery, 460Wh, 40x3.2Ah, ANT+/Bluetooth connectivity, IP 67
CHARGER Custom charger, 42V4A w/Rosenberger plug
WIRING HARNESS Custom harness w/ Rosenberger plug
https://www.specializedconceptstore.co.uk/product/5519/2017-2017-turbo-levo-fsr-comp-6fattie/
