For Sale (BIKE) 2017 Specialized Turbo Levo FSR Comp 6Fattie: £2300
Relaxitscool
Bike Year: 2017
Manufacturer: Specialized
Model: Turbo Levo FSR Comp 6Fattie
Asking Price: £2300
Description:
For sale is my Specialized Turbo Levo FSR Comp 6Fattie limited edition in Candy Red, frame size large. I've owned this bike for nearly a year having purchased it from the first owner. It's been great fun to own and ride but its just not getting the use it should, and being a one ebike household does cause issues when we ride as a family.
The bike has been used and there are some signs of wear which the new pictures will show, but they are so small they need pointing out to be noticed. The frame has no dents or chips and the suspension is tight and the forks were serviced recently, with only a couple of hours riding since.
**The bike has just come back from the LBS where the updated Brose 1.3 motor was fitted, new harness, new speed sensor bringing the drive train up to date and zero mileage**
For more details about this bike please follow this link
Turbo Levo FSR Comp 6Fattie | Specialized.com
This is the comp version with following specs:
FORK RockShox Yari RC 29/27.5+, Solo Air spring, adjustable compression and rebound, 15x110mm Maxle Ultimate thru-axle, 51mm offset, 140mm travel
FRAME Specialized M5 Premium Aluminium, Trail Geometry, integrated down tube battery, enclosed internal cable and Command Post IR routing, 148mm spacing, fully sealed cartridge bearings, 140mm
of travel
CHAIN SRAM PCX1, 11-speed w/PowerLink
CRANKSET Custom alloy crankarms
SHIFT LEVERS SRAM GX, 11-speed, trigger
CASSETTE SRAM XG-1150, 11-speed, 10-42t
CHAINRINGS 32T
REAR DERAILLEUR SRAM GX, long cage, 11-speed
BATTERY Custom LEVO battery, 460Wh, 40x3.2Ah, ANT+/Bluetooth connectivity, IP 67
UI/REMOTE Integrated Trail display, 10-LED battery display, Mission Control iOS/Android App
CHARGER Custom charger, 42V4A w/Rosenberger plug
MOTOR **New version 1.3** Custom & exclusive for Specialized, Trail tuned, 250 W
WIRING HARNESS Custom harness w/ Rosenberger plug
FRONT HUB Specialized disc, alloy, sealed cartridge bearings, 110x15mm thru-axle, 24h
REAR HUB Specialized disc, alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
INNER TUBES 650bx2.3"/3.0", 40mm Presta valve
SPOKES DT Swiss Industry, stainless
FRONT TYRE Purgatory, GRID casing, 650bx3.0", 60TPI, Aramid folding bead, 2Bliss Ready
REAR TYRE Purgatory, GRID casing, 650bx3.0", 60TPI, Aramid folding bead, 2Bliss Ready
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Command Post IRcc, 12 position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm, M/L/XL: 125mm travel
STEM Specialized Trail, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 750mm width
GRIPS Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness
REAR SHOCK FOX FLOAT Performance, Rx Trail Tune, AUTOSAG, DPS damper, rebound and 3-position compression adjust, 197x47.6mm
FRONT BRAKE SRAM Guide R, hydraulic disc, metallic pads, Guide S4 4-piston caliper, 200mm rotor
REAR BRAKE SRAM Guide R, hydraulic disc, metallic pads, Guide S4 4-piston caliper, 200mm rotor
SEAT BINDER Alloy, 34.9mm
If you have any questions please feel free to contact me.
I might have read your advert too fast so forgive me for asking:
What size is it?
Where are you located?
I am in the market for a XL
    673K
