Your Levo Comp Alloy is a cracking bike — Specialized 3.1 motor (105Nm/810W post-OTA), 840Wh battery, 160/150mm travel — but it's not cheap. If you're after that kind of capability for less, here's where I'd actually look.
The obvious one — drop a trim in the same family
The
Specialized Levo 4 Alloy base trim is
£4,799 — same 3.1 motor, same 840Wh battery, same 160/150mm travel and geometry as your Comp. You give up the Fox 36 Rhythm for a Marzocchi Bomber Z1, SRAM Maven brakes become DB8s, and you lose the T-Type drivetrain. But the bits that define how it rides — motor, battery, frame, travel — are identical. Best value-per-pound if you like the Levo platform.
Cheaper-but-genuinely-good rivals
The strongest budget play in full-power eMTB right now is anything on a
Bosch Performance Line CX Gen 5 — now 120Nm on the current Performance Update 2.0 firmware, 750W claimed peak. Brands like Cube, Canyon and Vitus routinely undercut Specialized by £1,000+ for comparable kit:
| Bike type | Motor | Why it's worth a look |
| Canyon Spectral:ON (direct sales) | Bosch CX Gen 5, 120Nm | Consistently the best spec-for-money; 750-800Wh options |
| Cube Stereo Hybrid | Bosch CX Gen 5, 120Nm | Big battery, aggressive UK pricing |
| Vitus E-Sommet | Shimano EP801, 85Nm/600W | Enduro travel, often heavily discounted |
The Shimano
EP801 (85Nm, 600W) is the value-motor staple — less peak grunt than your 3.1, but proven and everywhere.
The honest steer
If you genuinely want to spend less without feeling short-changed, the £4,799 base Levo Alloy is the easiest win — you keep the motor and battery that make your bike good. If you're willing to switch ecosystems, a direct-sales Bosch CX Gen 5 bike gets you more torque per pound than almost anything, and the consensus on here is that the Gen 5 firmware bumps have transformed it from "fine" to "genuinely punchy".
What's the budget you're trying to hit, and is it the cheaper sticker you're after or lower running/spec compromise you'll actually live with? That'll sharpen the picks right up.
