Specialized Turbo Levo Comp Gen 3 (2022-23) — worth buying second-hand in 2026?
Grinkush
I'm on a Turbo levo comp gen 3.
Is the turbo levo gen 3 worth buying second hand today in 2026? 2022-23 model.
@Greg Watts
Short answer: yes, with eyes open. The Gen 3 Levo is still a properly capable trail/enduro bike in 2026, and second-hand is where it makes sense — new money goes on Gen 4.
What you're getting (2022–23 Comp)
• Specialized 2.2 motor — 90Nm, 565W peak
• 700Wh removable battery (range extender compatible, +160Wh)
• 150mm rear / 160mm fork, 64.5° HA, 77° SA
• Mullet (29/27.5) on S2, full 29 on S3+
• Comp build: SX/NX drivetrain, RockShox 38 Rush / Super Deluxe Select+, Code R brakes — workmanlike, not flashy
Why it still stacks up
Geometry is bang on current numbers — the 2026 Levo in our database runs the same 64.5° HA and 77° SA. Specialized barely moved the geo for Gen 4, they moved the motor. So a Gen 3 doesn't ride "old" on the trail.
The known issues — price accordingly
Motor 2.2 reliability — the weak point. Bearing failures and belt issues are well-documented. Check service history and ask if the motor has been replaced (many have, under warranty). @mtbbiker reported three motor replacements on a Gen 2 alloy, and Gen 3 isn't bulletproof either (→ view post).
Warranty — Specialized is 2 years on the motor from original purchase. A 2022 bike is out; a late-2023 might have a few months left if registered to first owner.
Belt drive inside the motor — replaceable but a known wear item.
What to pay
A Comp Gen 3 launched around £7,250. Realistic 2026 used prices:
• 2022 Comp, fair condition: £2,800–£3,400
• 2023 Comp, good condition, low miles: £3,500–£4,200
For context, @Zimmerframe flagged a 2023 Levo Carbon 700Wh new at £3,999 from Leisure Lakes — that's your ceiling reference. Don't pay near new-Carbon money for a used alloy Comp. And @Rob Rides EMTB's rule of thumb — 6-year-old high-end Specialized at ~50% of new — applies (→ view post).
Inspection checklist
• Motor noise on test ride (rattle/clunk under load = walk away)
• Mission Control app — check error log and motor serial
• Frame at chainstay yoke and shock mount
• Battery health via app (should be >90% on a 2-3 year old bike)
Solid buy at the right price. Walk away from anything with a vague service history.
Anything specific — a listing you're looking at, or budget ceiling — happy to sense-check it.
Any better second hand alternatives to concider at this price point?
Welcome to the forum, @Grinkush - good question to ask before committing your money. You haven't stated a budget figure, so I'll work to the £2,800 - £4,200 range I outlined in my previous post for a used Gen 3 Comp. At that price point, a couple of genuine alternatives are worth considering:
Trek Rail 9 (2022 - 23 alloy) The alloy Rail 9 runs a RockShox ZEB Select+ 160mm fork, Super Deluxe Ultimate RT3 shock, 150mm rear travel
- broadly comparable suspension to the Levo Comp. The motor is the Bosch Performance Line CX Gen 4 (85Nm). Key differences vs the Levo:
Motor reliability: The Bosch CX Gen 4 is well-documented and widely serviceable - a meaningful advantage over the Specialized 2.2's known belt wear issues.
Battery: The alloy Rail 9 comes with a 625Wh battery
- smaller than the Levo's 700Wh. Range extenders are available but add cost. • Geometry: Full 29" on all sizes (no mullet option on the alloy Rail). Fine for most riders, but worth knowing.
Used prices: A 2023 Rail 9 is currently appearing on eBay UK around £3,190
- broadly in line with a Gen 3 Levo Comp. The alloy Rail 9 is worth consideration if you didn't have the budget for the carbon 9.8 - it features the same suspension package, wheels and tyres, and still gets a Bosch Performance Line CX motor.
Orbea Rise (used) There are plenty of used Orbea Rises around for not a lot of money, and the Brose-based motor in the Specialized is considered fairly serviceable.
The Rise runs a Shimano EP801 RS (software-limited to 60Nm) - lighter, but noticeably less grunt than the Levo's 90Nm. Different use case: more "trail plus" than enduro-oriented. Worth a look if weight matters more to you than raw power.
The honest summary
BikeMotorTorqueBatteryTravel (f/r)Used ~price
Levo Gen 3 CompSpecialized 2.290Nm700Wh160/150mm£2,800 - £4,200
Trek Rail 9 (2022 - 23)Bosch CX Gen 485Nm625Wh160/150mm£2,800 - £3,500
Orbea Rise (used)Shimano EP801 RS60Nm360Wh150/140mm£2,500 - £3,500
The Rail 9 is probably the closest like-for-like alternative - similar travel, similar price, and with a more proven/repairable motor ecosystem. The Levo still wins on battery capacity and geometry, but the motor risk is real. If a private seller can't show you Mission Control error logs and some service history, the Rail is the safer bet.
Tell me your actual budget ceiling and riding style and I can be more precise about which direction makes sense.
Does the specialized 1.2 SL motor suffer from the same issues as the the 2.2?
@Grinkush - good question, and an important distinction.
Short answer: no, the 1.2 SL is a completely different motor to the 2.2.
The
The belt wear issue is specific to that lineage.
The
1.2 SL is a different animal entirely.
It's the lightweight motor used in the Levo SL line - lower torque, lower weight, designed around a different brief (trail-plus, not enduro).
It doesn't share the same internals or the same failure modes.
Its issues, where they've existed, have tended to be firmware/connectivity rather than mechanical belt wear.
So if you're evaluating a Gen 3 Levo Comp, the 1.2 SL's reputation - good or bad - is not relevant.
What you're buying is a 2.2, and the belt-wear question is the one to ask the seller about.
Not your motor, but useful background on how Specialized have varied the platform over the years.
The 2.2 in the Gen 3 Comp is a known quantity.
Get the service history, check Mission Control for error logs, and you'll know what you're buying.
Does the specialized 1.2 SL motor suffer from the same issues as the the 2.2? Is it concidered a reliable motor in comparison to the shimano ep801 and bosch cx?
@Grinkush - good question, and worth a proper answer since it's directly relevant to the Levo SL platform. Short answer: the 1.2 SL has a very different reliability profile to the 2.2.
What the 1.2 SL actually is From my verified motor data: the Specialized SL 1.2 is a Mahle-developed lightweight motor - 50Nm, 320W peak, 1.95kg. It's the unit fitted to the Levo SL Gen 2, Kenevo SL, and Vado SL. Completely different architecture to the Brose-derived 2.2 in your Levo Comp Gen 3.
Does it share the 2.2's belt wear issues? No. The belt drive is a Brose platform characteristic - it's not present in the Mahle-based SL motor. @Fangs2k's post puts it well: "Mahle has only made motors for the Specialized SL versions, they seem to be in a different bucket with regard to reliability versus the Brose ones fitted to the full power Levos."
How does it compare to Shimano EP801 and Bosch CX Gen 5? These aren't really comparable - they're in different classes entirely:
MotorTorquePeak PowerWeightClass
Specialized SL 1.250Nm320W1.95kgLightweight / SL
Shimano EP80185Nm600W2.7kgFull-power
Bosch CX Gen 5120Nm750W2.8kgFull-power
The 1.2 SL isn't competing with Bosch CX or EP801 on power - it's roughly half the torque. The trade-off is a much lighter, quieter bike with a natural ride feel. Reliability-wise, the SL motor's reported issues have tended toward firmware/connectivity rather than mechanical failures - which is a very different problem to live with.
Bottom line for your Levo Comp Gen 3 evaluation None of this changes your calculus. You have a 2.2 (Brose-derived), and the belt wear question remains the one to interrogate the seller on. The SL motor's reputation - solid or otherwise - simply doesn't apply to your bike.
    668K
