Price £2,500 o.n.o
Used for less than 600kms, all commuting to and from work, and has been sat unused for the last 2years.
This 2020 Creo SL Expert Carbon is in very good condition with only a few ‘shed scars’ caused by pulling my other bikes in and out of the shed.
Battery health is 100%, only 13 full charge cycles.
Motor has been ‘tuned’ by Berkshire Cycles.
11 speed XT/Ultegra Di2 components.
Also included:
Both the bike and Di2 chargers.
Topeak waterproof saddle bag.
Range extender and cable, never used.
Wahoo Bolt computer with wheel and crank sensors.
Set of SKS Raceblade Pro mudguards, still boxed and never fitted.
Pair of SPD/flat touring pedals (just some old pedals fitted for collection).
Probably could do with a little service due to length of time it’s sat unused, but it does ride, changes gear, and stops as it should.
Bike is located in Chichester.
Buyer collection only, I do not have the ability to pack/post.
Open to sensible offers.
Original specification from the Spesh website:
Motor:
Specialized SL 1.1, custom lightweight motor
UI/Remote:
Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®
Battery:
Specialized SL1-320, fully integrated, 320Wh
Charger:
Custom charger, 48V System w/ SL system charger plug
Wiring Harness:
Custom Specialized wiring harness w/ chargeport
FRAMESET
Frame:
FACT 11r carbon, Open Road Geometry, front/rear thru-axles, fully integrated down tube battery, internal cable routing, fender/rack mounts, Boost™ 12x148mm
Fork:
Future Shock 2.0 w/ Smooth Boot, Boost™ 12x110mm thru-axle, flat-mount disc
Seat Binder:
Specialized Alloy, 30.8mm
BRAKES
Front Brake:
Shimano Ultegra R8070 hydraulic disc
Rear Brake:
DRIVETRAIN
Rear Derailleur:
Shimano Deore XT Di2, Shadow Plus, 11-speed
Shift Levers:
Shimano Ultegra Di2 Disc R8070
Cassette:
Shimano XT, 11-speed, 11-42t
Chain:
Shimano Ultegra, 11-speed
Crankset:
Praxis Forged/M30 Spindle Interface
Chainrings:
46T
COCKPIT
Handlebars:
Specialized Hover Expert, Alloy, 125mm Drop, 75mm Reach w/Di2 Hole
Saddle:
Body Geometry Power Expert
Stem;
Future Stem, Pro
Tape:
Roubaix S-Wrap
SeatPost:
S-Works FACT carbon 27.2mm, 20mm offset
WHEELS
Front Wheel:
Roval C 38 Disc, carbon, tubeless-ready, 38mm depth, 24h
Rear Wheel:
WHEELS & TIRES
Front Tire:
Specialized Turbo Pro, 700x28mm
Rear Tire:
Inner Tubes:
Presta, 48mm valve
Also included:
Motor:
UI/Remote:
Battery:
Charger:
Wiring Harness:
FRAMESET
Frame:
Fork:
Seat Binder:
BRAKES
Front Brake:
Rear Brake:
DRIVETRAIN
Rear Derailleur:
Shift Levers:
Cassette:
Chain:
Crankset:
Chainrings:
46T
COCKPIT
Handlebars:
Saddle:
Stem;
Future Stem, Pro
Tape:
Roubaix S-Wrap
SeatPost:
WHEELS
Front Wheel:
Rear Wheel:
WHEELS & TIRES
Front Tire:
Rear Tire:
Inner Tubes:
Presta, 48mm valve
