YT Decoy first ride review: A brilliant ebike with outstanding performance
Status
Not open for further replies.
Sorinok
73
154
Romania
The same mail I received today, the bicycle will be sent to 26th week, although it had to be delivered on 22 May. In my order I now show that I have the free shipping and the box, but the money has not yet entered the credit card.
Nasty Nick
244
176
Ventura, CA US
I have a small battery range anecdote. I rode with a friend in a mix of boost and trail. I didn’t use any battery saving techniques. My friend and I paced with each other. I ran out of juice about 2 km from the car, his trek powerfly did not.
I’ve noticed it takes a long time for the first bar to drop off the battery indicator. But the last two bars go really fast. It has given me a false sense of range and has led me to run out of power on other rides.
Fivetones
898
904
Cheshire
There are way too many variables going on in the mix here. I can’t see how anyone can draw any conclusions.
To compare you need lab conditions.
Eckythump
832
680
North Yorkshire
I dunno, I think Nasty Nick's comparison is probably more valid in the real world than a lab test.
It does kind of fly in the face of other reports particularly from the launch.
A conspiracy theorist might wonder if the press launch bikes were fitted with the upcoming 700wh packs.......
Nasty Nick
244
176
Ventura, CA US
People might think I’m a hater, but I’m not, I really like the bike. I’ve just found the battery and weight to be a little disappointing as they’re not as good as advertised, in my experience.
knut7
Administrator
661
1,226
Norway
The Decoy battery is probably a 30 cell using 21700 5000mAh cells. That's the only way I get to 540Wh. Weight is about 70g for these cells. A 700 or 720 Wh battery is 40 cells, so the weight difference should be about 700g.
As far as I know, 5000mAh is the biggest 21700 cell currently available.
Eckythump
832
680
North Yorkshire
The 700Wh would still weigh more regardless...
Really?
The following as an example are all 21700 cells from Samsung.
30T 3000mah 68.2g
33J 3270mah 68.9g
40T 4000mah 66.8g
48G 4000mah 67.4g
50E 5000mah 68.7g
Cell weights has more to do with charge/discharge rate than capacity.
Eckythump
832
680
North Yorkshire
Odd the larger pack isn’t available from launch if the plan is just to add an additional 10 cells of the same type.
knut7
Administrator
661
1,226
Norway
Yeah, not sure why they're delaying the 700Wh pack. Could be they can't get hold of enough cells. I guess the bike looks better with a 30 cell battery, that might be a factor.
In 2015/2016 the 18650 cells reached 3500mAh. That's an energy density of about 250Wh/kg. In 2018/2019 we got the 18650 3600mah and the 21700 5000mah with ~260Wh/kg. To make a 700Wh battery with 30 cells, we need 6500mAh cells. That's an increase of 30%. I guess that would be about 320Wh/kg. That's a huge increase compared to the progress made the last 4 tears. I havent heard of any big breakthroughs in battery tech that would allow this kind of density, so I don't think a 700Wh 30 cell 21700 battery is possible atm.
Eckythump
832
680
North Yorkshire
My thoughts are the pack is currently 40 cells. Something around 3750’s would give 540wh. The delay for the bigger pack might be in securing sufficient quantities of higher capacity cells of sufficient C rating.
Why engineer two different packs when you can get away with one.
40cells would approximately weight 2760g which would fit in with the total pack weight of 3170g.
Jedipip
178
198
Yorkshire
So showing signs of not being as efficient as the existing competition then??
Ecky....quite the opposite.
My experience to date is that Rob was quite correct. The battery and motor combo is certainly looking better than the competition.
20 miles today. Mostly in eco (which is a little too powerful if I’m honest) and a range of 68 miles on it when I got home. 1 bar down. 4 to go.
That’s a 13.5 stone bloke riding in muddy conditions and climbing 2500ft.
Plenty of trail and boost in there to ease the grind.
Do I wish I’d got the Levo/Kenevo?
Nope, not yet.
Q
Q-Ball
Guest
Well I'm not sure how this stacks up but I came back from a 25-26 mile ride with 4600 ft climbing (mostly dirt) in a mix of Eco and Trail modes. Came back with 2 bars still showing with the stock tires and a 188lb rider. My buddy on a Focus Jam2 with the 2 battery system came back with 3 bars left on his 2nd battery. I've just changed the chain ring to a stainless 32t in order to help with the cadence when climbing the long steep sections of Mt. Diablo in California. We'll see what that does to range.
One item I'd like to ask folks with delivered bike: Are you having issues with the frame grommets staying in place where the cables comes through? Mine keep moving about and I've got a few ideas that require small cable ties to try and solve this.
Status
524K
