Levo 2019: power readings in MC way to high!
McInner1
227
173
Austria
Hello! I‘m new here.
I‘ve got my Speci Levo 2019 (S-Works) some days ago, set all up and did my first rides.
Problem:
The biker-power-readings are way to high - both at Mission Control and on Garmin Edge (ANT+).
Both, the MC on my iPhone and my Garmin Edge 1030 show the same ridiculous high values such as 600 Watt with easy pedalling.
My TCU-firmware is 13.a.
Is this the latest firmware?
Is the firmware a possible reason for my problem?
Thanks for your responses!
Maastricht
646
655
M
You
Problem:
EDIT: sorry for wrong naming my bike - it’s a Levo of course, not Lenevo (oh my dear...)
You seem to run the first firmware version which contains these bugs. See also this post:
The Official BLEvo Thread - EMTB Forums
I think you need to upgrade your firmware and then the issues will be solved. I would also recommend to use BLEvo.
McInner1
227
173
Austria
About firmware-versions:
What's making me think is that:
-BLEvo shows TCU-version: 3.019 (it must be very new, right?)
-MC shows TCU-firmware 13.a (isn't v17.b already available?)
Indigo
214
178
Brisbane, Australia
If I were you I would keep version 3.019 -- just so I could change the speed limit in BLEvo.
BTW. Your lbs only needs a micro USB cable connected to TCU.
The earlier bikes, 2018 Levo & 2019 Kenevo require a special cable that plugs into battery.
Maastricht
646
655
M
Have you seen the table of which I shared the link in previous post? Here you will find the three firmware versions.
Indigo
214
178
Brisbane, Australia
Oh okay, this table:
13988
I also took delivery of Levo 2019 (S-Works) recently and I watched as lbs updated TCU firmware from 3.019 to 3.025 and then to 3.026. The 3 (instead of 2) must be for newer TCU hardware version?
BLEvo reports mine as TCU hardware version 3.1
Maastricht
646
655
M
13988
I live in Europe and have TCU hardware version 3.1 just like you. Maybe firmware versions 3.019/3.025 and 3.026 differ from 2.019/2.025 and 2.026 due to different base (25km/h vs. 20mph) speed region. I am over asked here.
I do know that the speed of 2.019/3.019 can be adjusted via BLEvo where at the newer versions this is not possible anymore. Unfortunately firmware version 2.019/3.019 contains several bugs which are related to shuttle mode, biker power (or motor power I now start to doubt however you will see unrealistic figures) and walk assist.
McInner1
227
173
Austria
Just visited my LBS and they updated my TCU.
Now all works as it is supposed to do!
BLEvo TCU Version: 3.026 Hardware Version: 3.1
MC TCU firmware: 1a.b Hardware A.1.0
HAPPY!!
Kave
242
151
Sweden
I also have the old firmware on my two week old bike. I am planning on keeping it that way. I don't care about the rider power being wrong.
I sometimes have a hard time connecting my phone with Blevo with it, but I guess that won't be fixed with new firmware anyway. I am enjoying my unrestricted bike for now.
526K
