Great job! Could you share these actual numbers how the Trail mode differs from other modes (when set to same assist and torq. levels)? And what do you mean by Trail mode "self-adjustment"?
I have been playing with the assist level settings and I would be happy to learn something new. Currently Eco and Trail have been set for long rides to save battery and Boost is like default Trail. But based on your analysis, probably Trail would be most suitable to be set as highest assist level (Eco and Boost to 2 lowest assist levels), in case it does some magical "self-adjustment".
Let's try this again, I'll try to explain it a different way. I''m going to change some words to hopefully make it easier to understand:
Starting with firmware 4.6.1, in the E-Tube software the default PROFILE is "Dynamic". In the Dynamic Profile, the assist settings are:
ECO MODE = 60% assist, maximum
30Nm torque
TRAIL MODE = 70% assist, maximum
70Nm torque
BOOST MODE = 300% assist, maximum
70Nm torque
Basically this means:
In
ECO MODE (60%/30Nm), when you spin the crank, the STEPS motor will match your power output + add 60% assist. No matter how slow or fast you pedal, ECO MODE will ALWAYS give you 60% assist (no more, no less), but it will NOT produce any more than 30Nm of motor torque.
In
BOOST MODE (300%/70Nm), when you spin the crank, the STEPS motor will match your power output + add 300% assist. No matter how slow or fast you pedal, BOOST MODE will ALWAYS give you 300% assist, and it will ALWAYS produce 70Nm of motor torque.
Now we move to
TRAIL MODE (70%/70Nm). The simple explanation is: in TRAIL MODE (pre-4.6.1) when you spin the crank, the STEPS motor will match your power output + add 70% assist, up to 70Nm of motor torque.
However, with the
4.6.1 firmware update, there's more to
TRAIL MODE as opposed to
ECO and
BOOST. Shimano refers to TRAIL MODE as an "intuitive pedal assist"; so although TRAIL MODE starts at 70%/70Nm, the actual pedal assist output is variable depending on the actual force you put into the pedals. So in their own words, "Pedal harder in Trail mode and your get stronger motor assist. So when you are really torquing it on something short & steep, the E8000 will match your efforts up to its max 70Nm output."
In other words, in TRAIL MODE the software is using the input torque (how hard you push on the pedal) to constantly adjust ("self-adjustment") how much motor assist - whereas in ECO and BOOST MODE are basically just preset values that always stay where they are set at.
So when used as intended, you can call ECO MODE "limited mode" in that it will limit motor assist to limit battery drain; you can call BOOST MODE "maximum mode" in that it will give you the maximum assist and torque at all times; finally, as suggested by Shimano - TRAIL MODE is the "all-around mode" in that you should be in TRAIL MODE the majority of the time you are riding your e-bike.
This is how the Shimano rep explained it to me, hopefully that is easier to understand with regards to how the STEPS system works, especially with 4.6.1.
