New CEF69 bafang m510 and bafang m560 and cef50 bafang m820 frames
Thanks Ficorama. ;)
Focusing on user friendly interface. Will have to add some text with explanations. But I am lazy for this job. ;)
This Chrome over USB works very well. Been thinking about BT connectivity first, but Bafang does not have +5V pin on a display connector. :( So stayed with a cable.
Loading firmware files works just fine? (Some bugs can occure. I have never did a client server app. Apart of some easy at Uni lot of years ago). Will add some FakeTaxi firmwares for M820 guys.
Hi Guys
So i have been trying to work out how to put custom rides into the app as can't navigate on trail there is no end GPS location example, so i found this website bikerouter.de Create your route then you downlaod and import it into Bafang Go app with GPX file and works great don't incldue Waypoints it seems to fail all time,
Now your rides will sync with strava from the imported GPX file and its free
@Dado , Great work as always
Cheers
-M560RS
- 14s3p 840Wh
- KOCEVLO Carbon Fiber Pedal
- ONEUP COMPONENTS V3 - 210 mm
- ZTTO 11-46T SLR 10s
- SYNCROS Hixon IC SL 5 °
- RockShox Lyrik Ultimate Charger 3.1 RC2 29" DebonAir+ Tapered Boost
- RockShox Deluxe Ultimate RCT DebonAir+ Trunnion
- Magura MT Trail
- ELITEWHEELS 29er MTB Carbon Wheelset Ultralight Trail XC M14 Ratchet System 36T
- Schwalbe Nobby Nic 29x2.60 Performance Line
- L-Twoo T9 +L Twoo T7
Requested some information from Jean regarding the CEF69, as I was considering one, I think others may find this info useful as well.
Suspension:
- maximum rear travel is 165mm from 65mm stroke shock, not 180mm as suggest by the geo chart.
- links exist for 210x55 (142mm travel) and 205x60-65 (147 - 165mm travel).
- leverage curve is progressive, ratio 2.9 - 2.3, i.e. progression ~26%.
Usage:
Q: Is it OK to use dual-crown (downhill) fork, e.g. RockShox BOXXER? Is the frame strong enough for big jumps?
A: "this frame is an enduro frame, not a downhill frame. We do not recommend using it for big jumps."
Motor:
Q: Is the M560 motor the new version with torque+speed sensing? Does it utilize the ABS-ring style sensor in the rear?
A: "The M560RS motor is temporarily out of stock. You can use the M560 motor first."
Q: Can it be delivered with motor unrestricted (i.e. assist up to 45 km/h)?
A: "Bafang requires the maximum speed to be set at 45 KM/H; any speed exceeding this will not be covered by after-sales service."
Price:
frame + M560 motor + 835 Wh battery + range extender 240Wh + 4A charger + display, wiring etc. = 2160 USD
-M560RS
- 14s3p 840Wh
- Magura MT Trail
Nice work but I fear that the freewheel, not being designed for EMTB, will not be able to handle the power of the M560 engine.
new beast. weight approx. 22 kg as in the pictures. tried a short ride, the engine is quieter than the fc 2.0. power very good. real test tomorrow.
Battery 11s3p 21700
Wheelset Syntace C33G carbon 29
Shifting Sram gx
Magura mt7
Trp 220 2.3 rotor
Oneup 240mm dropper
Raceface carbon handlebar 35
Cranks 152mm
Crankbrothers mallet pedals
Fox 38 rhythm fork
Fox float x shock
still needs a little adjustment, tightening the hoses.... mostly I'm satisfied
    Join 43,231
