SZZS CEF69 Build with New Bafang M510 3.0 version
Can anybody share there cable management? Mine seems to make a lot of noise. lol
Didn't really plan it out coz too excited to ride. I might have some time to disassemble it and do it properly
use foam tube
En un cuadro cef69 alguien podría decirme en talla L cual es la longitud máxima de tija que entra dentro del cuadro
Guys, сould you please help me with two questions? What is the fundamental difference between RS motors and their standard versions? What is the maximum rear tire width/clearance for the CEF69 frame? Thanks in advance for your help!
I have 2.
Mate, I think the FC4.0 Might have same internals as the RS but Bafang are no longer making FC4.0 standard M510 gone back to FC 3.0, Mine is definitly noisier then the FC2.1 etc
For wheel size i have a 2.6tire on rear im sure you could go bigger.
I have 2.
At the beginning I thought that FC4.0 was noisier than FC2.1 but after about 500km they seem to be similar in noise.
FC4.0 is very smooth with stock tuning.
I am very curious what is the real difference FC4.0 vs FC3.0.
Cheers
aww! as far as I remember there were similar things on cef50 frames. what is the shaft diameter?
11.9mm , so about 12mm. And around 81.7mm long... I saw specialized uses a rear suspension pivot bolt thats 12mm wide x 82mm long....
It was starting to creak, so I did a torque check on the bolts and pop goes the weasel!
My frameset has done alot of downhill. Over 1000km on it now.
you can also cut a thread on the side where it broke and put a washer on it. at least temporarily until you solve the axle. or have made from an old 12mm thruaxle.
    Join 43,127
