Cube one77 2025
I have the SLX and I can't fault it. Had it just over a year and still going strong. I would 100% recommend the SLX for spec and value for money. The new Bosch update has made it a beast and is easily on par with the Amflow.
I'm at 4k km, bike has been ridden hard, all issues documented here, need to tighten the bolts after first few rides, some headset creaking I can't get rid of, but still a great bike for the price
Thanks for all the replies ^
Sounds like a solid choice. It's only the base model HPC 800 but it's $5,700 aud or $2,995 gbp - so plenty of room to upgrade things in future. I'll be sure to post a pic here once I pick up the bike! Very excited.. Bit torn on colour, they have the willowgreen, black and grey all in XL.
Thanks for the reply, I've started reading through this thread since page 1 and noticed you are the OG poster. The headset creaking you can't get rid of sounds pretty annoying - I'll try to find your posts in this thread about it
Excellente, what's not to like, a very capable bike indeed. 1200 km the fiber/plastic head cups creaked, greased them and quiet since.
Picked it up last night, my first eeb. Maiden voyage this arvo. Forks feel a bit naff but we’ll see after break in. So pumped
First impressions - loved the bike immediately even though set up was off (too soft, also shop cut the dropper cable super short so couldn’t get the post quite high enough).
Geo feels great, confidence inspiring. I like how low it is and feel like that added to the sense of stability at speed and ease of railing corners and berms, but I did clip my pedals a couple times pedalling in places I normally wouldn’t on my analog.
The crankset and chainring look like Temu level equipment, I wouldn’t mind getting a nicer looking chainring.
Also think I’m gonna need a mudguard for the rear. No doubt I’ll be swapping lots of parts out so will update along the way! Thanks all for the vote of confidence in this bike, am chuffed.
As of today up to 110km and 2500m of vert - in 4 days ive ridden double what I’d do in a week on the analogue bike, and I barely feel fatigued!! Tomorrow I’m going to see how far I can get range wise. Yesterday got down to 20% battery in 1hr 40 minutes (turbo whole time).
Started to understand why people don’t hate the extra weight (I weighed this at 27kg!), it does gain momentum faster and hold speed noticeably better in rough sections. Still adapting riding style but it is a sled, in a way it feels like my 2006 giant glory I rode as a teen but with way better geometry - same point and shoot inspiring ride. Totally anecdotal but did get a few top 10’s on local descents on Strava on my 2nd ride (I don’t race, just an indication that the bike is good and I’m comfortable!).
Main issue that’s appeared - I can’t get the rebound fast enough on the fork or shock. Still feels too slow even wound all the way out (especially the fork). Also the fork is not very supple. I see a Fox 38 and X2 in my crystal ball. Today the rear shock blew out a seal (?) - it’s still holding air and feels fine, so it’s just the dust seal. I’m gonna try remove the shock and pop it back in before tomorrows ride.
Absolutely zero regrets buying this bike, can’t believe how much fun I am having (from an ex e-bike hater).
Just fit it with coil DVO Jade X -and the difference is very significant. It's soooo better in handling small bumps. Let's see it long term, but I think I will stay with coil.
I have swapped a few parts off my analogue bike (which I haven’t ridden since buying this… but will get around to doing!).
I want to get a matching 27.5 rear wheel / but they don’t come in an e-bike version.
Could I run the regular Mavic Deemax dh rear wheel? Or the hub is not strong enough?
Go for it mate 👍
After 500km, four spokes have snapped in the stock rear wheel. Happened over two rides (first one went, then three - I shouldn't have been riding with a broken spoke so partly my fault). Took wheel into shop I bought it on the weekend - no spokes in stock, and no mechanic available to cut and thread spokes. Suggested I bring the whole bike back in so they can also 'check the gears and brakes'. Back on the analogue bike while I wait for that matching rear wheel from Bikeinn ^
The forks started to feel a little better, keen to do a lower service and see if they improve again. I did notice a very slight 'clunk' coming from the rear end when lifting the rear wheel off the ground, and compressing it through the first mm of travel. Went around in circles checking torque on all the bolts/shock mount - removed and greased the shock mount bolts. Ended up deciding it was the garbage suntour shock and not worrying about it.
Do love the bike, it's awesome... but feel it will need a fork/shock/wheels to unlock its full potential.
Hi all,
Another new owner here. Also loving the bike.
I come from a 2020 Specialised Turbo Kenevo S4 and have gone to a M sized SLX.
I have removed, greased and locktited all bolts. Have some 145mm Pinnd cranks inbound, a Oneup 210mm dropper and an AVS motor plate on their way also.
I have shortened the bars to 760mm and dropped the stock stem to the bottom.
Loving the bike, and the change. 250km on it now, 90 in the last 2 days with a couple PRs and a 2nd on one decent.
Only issue I'm having is what I think are the front brake pads vibrating when in use. I can not feel it, but it makes a very strange noise.
Since you mention not being able to feel the vibrating, I assume it is the noise, and not haptic that the brakes make. I have a noise, a funny sound that only comes from the front rotor of my 8120's after a few thousand kms it is very subtle and I only notice it rarely in certain conditions. The noise I assume is from the shape of the cooling slots and it is soft and pleasant so I am not distracted by it. I am happy with the performance of the front brakes, they have been flawless. I did confirm that the caliper posts aligned the front pads with the center of the rotor surface area so it must just be an acustic quality for that combo.
Speaking of sounds...I've had my SLX for 14 months and only 555 miles.
I am hearing a clunking/knocking sound at the rear when climbing. It's when peddling quite slow. I have wiggled the bike and rear wheel and dropped the rear of the bike on its wheel to listen for anything. Nothing is loose and is quiet. No idea. Possibly the motor itself?
Has anyone had this situation and found the issue?
I occasional have a few knocks/chunks when riding since new that i can't explain, all is fine at 2k km
When you drive 3h to an amazing spot for holidays, and realize you must have lost your battery cover on the previous ride...
Funny enough, I found my battery cover loose when I got home on Sunday after a 30min highway drive home. Cover was hanging on the top button/bolt only. Like the bottom hooks had slipped up and out. I'm confident it was not loose when I lifted the bike onto the carrier on the back of the car.
I have isolated it to only making the clunking/knocking noise only when on the 5th cog.
Could it be a loose cassette lockring?
The cassette doesn't move when inspected though.
I had rattle sounds start at 1400 km, in the 4th cog up from the smallest. It was a worn chain that caused chain rattle.
The next rattle was a loose cassette that was a simple thing to tighten .
Found an example of my front brake noise.
You can hear it better in post #8
The chain is sound. I'll check the cassette. Thanks.
Very sensible cobble there! I lost mine before a ride and continued regardless, the amount of crap collected inside the downtube was depressing. Never again!
Yes I got lucky I had a bunch of cardboard to protect the bikes in the boot and some tape. It takes me 10minutes to do each time I charge the battery in the tiny apartment I rented, but yes the lower terminals would get wrecked with mud
In regards to brakes… I've been putting some serious heat into them lately — the 203mm rotors have gone through a whole spectrum, blue, purple, right down to "India ink," from sustained braking on long descents. Given that, I've decided to just do the full monte rather than patch the worn parts: so... new rotors, new caliper posts, new pads, the works.
Going up to 220mm rotors for the extra thermal capacity, along with taller caliper posts to match. I'm also holding out a bit on the pads, since I understand Shimano's got new rotors coming out this fall in some more standard sizes, hoping to grab those once available so I can bump up to 2mm thickness at the same time rather than doing this twice.
I'm on SRAM HS2 220mm rotors for the past 2-3 years on my main bikes, huge upgrade regardless of the brake (had SRAM codes, magura mt5 and now shim XT)
That’s awesome you’re already ahead of the game with the bigger rotors, man. I’m definitely a bit slow to the party on that one! 😂
Honestly, my experience with the Shimano XT 8120s has been absolutely unreal. I’ve been out in the Alps completely trying to melt these things on the long descents, and they just take the abuse. Love the lever feel, the modulation is spot on, and the reliability is bulletproof.
I totally get where you're coming from on the transitions, though. I had some SRAM Code Rs on a new rig a while back and they just weren't cutting it. And man, as much as I love the pure stopping power of Magura MT5s, dealing with the maintenance on them is a total headache. Sticking with the XTs is a solid call.
I'm sticking with Shimano because I love the lever feel, but I've actually had a bit of bad luck with mine needing a lot of bleeds to feel good (basically they feel bad with new pads needing less oil, then good for a few hours, then need a bleed to add oil again...) whereas my other brakes were solid but the lever activation needed way more strength
I've found the Shimano 8120s on my One77 predictable and reliable, but when I hop across to my Vitus Sommet enduro rig for the occasional non-e MTB ride, the Hayes Dominion A4 brakes on that just kick the living daylights out of the Shimano 8120 on the Cube; the Hayes are just better all around for feel, modulation and sheer power. Amazing how back to back riding can make you realise how something you previously got used to can be so much better or worse than you remember. If it wasn't a complete faff, I'd be tempted to swap the brakes around between the bikes; but the Shimanos get the job done (well) and I'd rather spend the time riding than in the garage swearing at brake components and cable routing (the headset bit in particular) 😆
The Xt’s for my needs of balancing budget and performance have been about 85 percent of what I need for actual lever pull to brake force. Hopefully going from 203 to 220 will bring that up a bit if it give me 10 to 15 percent performance boost in brake force and heat control.
So far, so good with my original setup, already burned through 3 sets of pads in 2800 km, though. I make it a habit to clean and lube the pistons every single time the pads get swapped, and I've got a bit of a theory on why it helps.
Throw the tin foil hat on with me for a second...
When a caliper piston gets sticky and doesn’t retract smoothly, and you release that brake lever back quickly, it creates a temporary low-pressure vacuum inside the caliper body. I'm thinking that sharp drop in pressure actually triggers cavitation or outgassing. It basically pulls all those microscopic, dissolved air bubbles straight out of the fluid suspension and clumps them together into one macro air pocket. Boom, spongy lever feel.
By keeping those pistons clean and lubed during pad changes, it keeps their movement smoother, symmetrical, and hopefully minimizes that sudden pressure drop, and possibly extends the life of the bleed. Seems to be working for me so far!
    Join 43,096
