Thanks for the reply, I've started reading through this thread since page 1 and noticed you are the OG poster. The headset creaking you can't get rid of sounds pretty annoying - I'll try to find your posts in this thread about itI'm at 4k km, bike has been ridden hard, all issues documented here, need to tighten the bolts after first few rides, some headset creaking I can't get rid of, but still a great bike for the price
Go for it mateI have swapped a few parts off my analogue bike (which I haven’t ridden since buying this… but will get around to doing!).
I want to get a matching 27.5 rear wheel / but they don’t come in an e-bike version.
Could I run the regular Mavic Deemax dh rear wheel? Or the hub is not strong enough?
Since you mention not being able to feel the vibrating, I assume it is the noise, and not haptic that the brakes make. I have a noise, a funny sound that only comes from the front rotor of my 8120's after a few thousand kms it is very subtle and I only notice it rarely in certain conditions. The noise I assume is from the shape of the cooling slots and it is soft and pleasant so I am not distracted by it. I am happy with the performance of the front brakes, they have been flawless. I did confirm that the caliper posts aligned the front pads with the center of the rotor surface area so it must just be an acustic quality for that combo.I think are the front brake pads vibrating when in use. I can not feel it,
I occasional have a few knocks/chunks when riding since new that i can't explain, all is fine at 2k kmSpeaking of sounds...I've had my SLX for 14 months and only 555 miles.
I am hearing a clunking/knocking sound at the rear when climbing. It's when peddling quite slow. I have wiggled the bike and rear wheel and dropped the rear of the bike on its wheel to listen for anything. Nothing is loose and is quiet. No idea. Possibly the motor itself?
Has anyone had this situation and found the issue?
I have isolated it to only making the clunking/knocking noise only when on the 5th cog.Speaking of sounds...I've had my SLX for 14 months and only 555 miles.
I had rattle sounds start at 1400 km, in the 4th cog up from the smallest. It was a worn chain that caused chain rattle.I have isolated it to only making the clunking/knocking noise only when on the 5th cog.
Could it be a loose cassette lockring?
The cassette doesn't move when inspected though.
Very sensible cobble there! I lost mine before a ride and continued regardless, the amount of crap collected inside the downtube was depressing. Never again!When you drive 3h to an amazing spot for holidays, and realize you must have lost your battery cover on the previous ride...
The chain is sound. I'll check the cassette. Thanks.I had rattle sounds start at 1400 km, in the 4th cog up from the smallest. It was a worn chain that caused chain rattle.
The next rattle was a loose cassette that was a simple thing to tighten .
Yes I got lucky I had a bunch of cardboard to protect the bikes in the boot and some tape. It takes me 10minutes to do each time I charge the battery in the tiny apartment I rented, but yes the lower terminals would get wrecked with mudVery sensible cobble there! I lost mine before a ride and continued regardless, the amount of crap collected inside the downtube was depressing. Never again!
In regards to brakes… I've been putting some serious heat into them lately — the 203mm rotors have gone through a whole spectrum, blue, purple, right down to "India ink," from sustained braking on long descents. Given that, I've decided to just do the full monte rather than patch the worn parts: so... new rotors, new caliper posts, new pads, the works.Found an example of my front brake noise.
You can hear it better in post #8
When bedding in the brakes of my new Haibike Lyke SE (purchased online), I noticed that the front brake was making strange noises. A kind of fluttering sound. Apart from the low performance, precisely because it hasn't been broken in yet, it doesn't feel bad in terms of pressure point or braking effect. Actually, it's just like the rear brake was at first, which, however, doesn't make any noise and now has much more braking power thanks to the process.
I've already checked several things.
The brake caliper is securely bolted, the disc is straight and runs smoothly. The inch bolt on the...
