Regarding the "Dead battery" dilemma, on the OWURU drive unit, there is a freewheel between the pedal axle and the chainring to allow a direct transmission of power when the motor(s) are off.
Source:
US20200198727A1 - Power train - Google Patents
The current E2 motor that's on the Decathlon city bike is not the same animal as the with the MG and X1P motors. Namely because the external drive gear is in
series with the crank chainring, perhaps allowing a freewheel to be employed, which I'm not exactly sure is a good thing:
The E2 motor showcased last year (still not released) looks to be quite similar the newer motors:
Cant remember if I already added to this thread, but according to Gobao
"We stop giving power when the battery reaches 10%. The system then only shift. Without power the ratio goes to the lowest and you can theoretically pedal."
That's just to conservative to take out such a huge chunk of battery capacity and moreover doesn't adequately deal with further degraded mode issues, like actual battery failure. There's more than one way to address this and we need Gabao to state how various degraded modes will work
Yes you did (or maybe in another thread).
I've posted something similar about the city bike Owuru drive unit which is since 2023 on the market and lacking the freewheel.
I guess future Owuru drive units like the announced Owuru Ride for e-mtb and cargo bikes will have it.
Contrary to the Gobao solution, the purely mechanical solution provided by the freewheel still allows to pedal when the battery is fully drained. However without shifting.
And obviously it's still possible to combine the software and the mechanical solutions.
Can I add to this, that whilst pedalling with no power in an E-CVT, the pedals will drive the smaller motor, MG2. This will generate some power so that you could technically vary the gear ratio, by slowing MG2.
Whether the MGU manufacturer allows you to use power generated by MG2 to vary the gear ratio, when the battery is flat, will be in the software design.
Remember. When MG2 is stationary. The gear ratio is about in the middle.
How would the secondary motor remain stationary during battery failure (not just discharge)? There would need to be some kind of secondary motor lock up mechanism (i.e. some kind of solenoid that locks the motor when power is lost) to hold the counter torque to allow power transfer of pedal torque to either to the output drive or generator to recharge the battery, or both. If the battery is damaged, there would be counter torque from the generator, so more power is transferred to the output drive. I see this as worst-case degrade mode support (say, Level 3).
In a higher-level degrade mode (say, Level 2), In a complete discharge scenario (but functional battery), After enough power in the battery is replenished through regen, the solenoid could activate, opening up the secondary motor for gear shifting as needed divert more pedal power to the output drive . This could be electronically regulated until you get safely home (would be a slog).
In the highest degraded mode (say, Level 1), basically a lower-battery mode, divert all pedal power to the output drive until such time that battery levels drop to level that requires rider input to divert torque to the generator (back to Level2)
