120 Nm update for the Bosch CX and CX Race Announced
Yeah, it's really annoying. I honestly regret installing the update...
Is it not possible to revert to the previous version? IMO all updates on any device/machine should be reversible because they often introduce more cons than pros!
Finally i got the 1.36.5 app version installed and then i updated my bike . Im gonna try the bike tomorrow to see if you can feel any difference.
OK I finally got the latest Flow app. update via Play Store but so far no corresponding update for the bike. Can anyone confirm there is a bike update associated with version 1.36.5 because when I check out the riding modes in the Flow app. in the "Advanced" section I'm not seeing an "Extended Boost" option, just the "Dynamic".:unsure:
OK I finally got the latest Flow app. update via Play Store but so far no corresponding update for the bike. Can anyone confirm there is a bike update associated with version 1.36.5 because when I check out the riding modes in the Flow app. in the "Advanced" section I'm not seeing an "Extended Boost option, just the "Dynamic".:unsure:
Yes when i updated the app version to 1.36.5 and open the app i got a bike update directly
Try to delete Flow app data from app menu.
You'll have to login again when you do it, it worked for me with the last update, I couldn't see it until I did so.
Thanks for that but given the update only just popped up in Play Store, it was not there first thing this morning, I will give it a bit of time to see if the bike part appears automatically.
What on earth are you meant to be running on the extended boost for each mode??
Auto default is 1, emtb+ default is 8 and turbo is also 1…how are you meant to decipher this?? 😂
What was it at (behind the scenes) before the update?? Is emtb+ default being 8 a bug and everything was 1? Meaning extended boost wasn’t really a thing before the update?
So confusing. So Bosch.
I believe that previously Extended Boost at whatever Bosch had set it to only applied in EMTB and Turbo mode, presumably there was only a small amount of boost assigned to Turbo as you already had more beans/power in Turbo.
Point is that you can set it to whatever you like now, some people don’t like overrun at all, others want it all the time.
There’s a bit more information in this Flowmountainbike article.
I think 8 under emtb+ is a bug.
1 feels about where it was pre update, which makes total sense with the dot indicating default for turbo.
I quite like 5, so will keep it there for a bit.
10 is a mess, way too much imo
I have to say, as a Kiwi, it’s nice to see the 45kmh update to Bosch.
It’s the only thing that has ruled out a Bosch powered bike for my next purchase (although that could be quite a long time off yet).
Riding a Shimano with 45kmh cutoff has changed the way I feel about top assist speeds.
For general riding I dont need the 45kph until it comes to racing and riding with other dudes on 45kph bikes. If everyone was at 32kph i'd be happy. But when a guy has a 45kph limit and i have 32kph limit in an enduro race thats a fair advantage they have. Also when riding with dudes with 45kph and they just peel off ahead its a pain in the arse...
In the ideal world i have 1 or two settings with the 45kph and the other 2 at 32kph.
I don’t use 45kmh often, but am often above 32kmh on both fire roads and certain trails. TBH my Shimano suits me just fine, despite the clacking. More torque would be nice though. And the Bosch certainly has that.
Yeah the 600%/ 120nm/750w is a fair chunk more than shimano 85nm/600w/400%.
Quite frankly i find that full power setting pretty silly.
I can only try to imagine the 150nm/1500w/800% of the avinox.
Dont complain 🤣. Here in EU we still only have 25kph and it sucks
I found a feature last night I didn't know i had.
Back pedal gear changing. .... wtf?
I thought it was motor run on at first. But no, it only happens with a slight back pedal.
if you coast and then do a slight back pedal the motor spins the chainring forward several revolutions without any drive and you can change gear coasting while coasting without pedalling foward.
Weird, Its an odd feature.
That's interesting and a feature I could genuinely utilize. It's nice because it doesn't require a wired drivetrain. Will test tonight.
So thankfully to have gotten rid of the stupid overrun with this latest update. Most important change yet by a mile.
On the speed thing, I still firmly feel that Class 1 max power should remain at 750w, but even 20 mph (actually 19mph on the Bosch) is just a bit too slow. I'm the exact opposite of Avinox's position that power doesn't matter, only max speed does.
Power allows crappy riders to go too fast for the given conditions, but max speed is genuinely a useful tool and if limited to 750w, can really only be used going DH or on roadways. 25 mph is a workable minimum, but 28 mph gets you keeping up with cars which is a nice feature to have.
Bosch is conservative and only gives 19 mph and 700 watts. Dieselgate hurt, I presume.
Interesting, will have to give that a go, updated mine with the extended boost and chain tensioner feature this evening but too late (and too hot!) to go for a spin this evening.
I was reading how the freewheel tensioner works and that's pretty much what was happening. So a by product of the freewheel tensioner is that you can change gear while its cycling forward while coasting.
The disadvantage for me will be perhaps more torn in half deraileurs or perhaps less. Time will tell.
I haven’t updated yet as I’m waiting to see if increased pedal kickback might be a consequence of the pretensioning.
Anyone experiencing such?
I did a fairly roudy down last night. Like 500mtr vert of double black roots and steep.
I didn't notice any difference. When it coasts forward there isnt any power as such being applied.
I have a home trail that is very rough just behind my home and I didn't notice any difference at all in PK, but then I don't feel like I have any anyways on my Wild.
Further to my earlier post, the bike part of the latest update was on offer in my Flow app .middle of the day yesterday and I installed without problem.:)
I went for a ride yesterday after the update, and I could really feel the Extended Boost, especially going uphill.
I like the new feel the bike got after the update.
Had anyone gotten to the bottom of this feature and what activates it? I'm thinking it's either power setting or speed sensitive.
It definitely did it once, I looked down and literally saw my chain ring spinning approximately 2 turns on it's own. Never could figure out how to make it occur and I can't get it to happen on the stand.
Thx
    Join 42,547
