After installing the latest Bosch firmware update to my Bosch performance cx race version 4 motor, it seems to be noticeably louder...is there an easy way to fix this?
@jbodnar - increased noise after a Bosch firmware update is a known phenomenon, but the cause depends on which update you installed and what "louder" means specifically.After installing the latest Bosch firmware update to my Bosch performance cx race version 4 motor, it seems to be noticeably louder...is there an easy way to fix this?
I installed the Performance Update 2.0 but I have the gen 4 motor BDU3760, not the newer gen 5 so the torque was not increased, but the motor seems louder going uphill in Race, emtb+, and auto modes (I currently don't use eco much; I believe my modes have not been customized).@jbodnar - increased noise after a Bosch firmware update is a known phenomenon, but the cause depends on which update you installed and what "louder" means specifically.
First, clarify what you're hearing: • Higher-pitched whine/mechanical tone - the Performance Update 2.0 (rolled out 4 May 2026) pushed the CX-R to 120Nm with 600% rider support. More torque delivery = more load on the drivetrain internals. Some riders report the motor sounds more "worked" under load. This isn't a fault - it's the motor doing more.
• Rattle or clunk at low power/cadence - this is a separate, pre-existing issue on Bosch CX motors generally. Worth noting that @DBSwiss found firmware updates didn't fix the low-power rattle - so if that's what you're hearing, the update likely didn't cause it either, just made you notice it.
Practical steps: • Check your chainring and crank are properly torqued - extra torque delivery will amplify any slop
• If it's a new high-pitched whine specifically under load at higher torque levels, that's expected behaviour post-update and not a symptom of damage • If it's a grinding or rhythmic knock, that warrants a dealer diagnostic - don't ride on it
I can't confirm official Bosch noise-level specs post-update (they don't publish those figures). If it's anything beyond a change in character rather than a new fault sound, worth getting it on a stand at your LBS and running through the Bosch diagnostics app.
What exactly does it sound like, and at what point in the ride?
@jbodnar - that's a useful clarification. If the torque wasn't increased (Performance Update 2.0's torque uplift is Gen 5 / CX-R specific), then the noise change on your Gen 4 is more interesting.I installed the Performance Update 2.0 but I have the gen 4 motor BDU3760, not the newer gen 5 so the torque was not increased, but the motor seems louder going uphill in Race, emtb+, and auto modes (I currently don't use eco much; I believe my modes have not been customized).
