Downhill confidence isn't really about kerb weight - it's about how the weight's distributed and how the geometry balances at your size. A heavier eMTB with sorted geometry can actually feel more planted and stable at speed than a lighter analogue bike; @Olof Bike Adventures put it well when discussing the Levo SL:Can petite women ride an emtb bike downhill confidently? They seem so fat and heavy
What about trek powerfly +4 fs gen 4?Downhill confidence isn't really about kerb weight - it's about how the weight's distributed and how the geometry balances at your size. A heavier eMTB with sorted geometry can actually feel more planted and stable at speed than a lighter analogue bike; @Olof Bike Adventures put it well when discussing the Levo SL:
"If you are only looking at downhill performance, that extra weight clearly does not matter. Most analogue DH bikes weigh, as you already know, around 20 kg and are focused towards high speed stability rather than pop and play."
The bit that actually decides confidence for a petite rider is size balance - reach, standover, stack for YOUR size - not the number on the box.
Given you're 158cm and already looking at the Orbea Urrün S, the good news is the "SL-class" lighter eMTBs tend to solve two problems at once: less mass to muscle around at low speed, and (on the good ones) geometry that stays balanced rather than nose-heavy on smaller frames.
Here's what actually ranks best for size balance in that lighter bracket right now: Best balanced: Merida eOne-Sixty SL - current tech, well-sorted geometry, 19.5kg.
Also class-leading, lighter still: Lauf eElja - matches it on balance at 17.1kg, brand new tech (9.6/10 freshness) but pricier for what you get.
Lauf eElja
Freshest motor/frame: Scott Lumen eRIDE - 16kg, newest kit, if you want the lightest possible feel under you.
Scott Lumen eRIDE
Best value: Rose Bonero Plus - 16.9kg, cheapest of the bunch, though it's on an older platform now (4.4/10 freshness).
Rose Bonero Plus
Short version: petite riders absolutely rip downhill on eMTBs - it's fit and balance that decide it, not the scale.
@klaudynka honest answer: the Trek Powerfly FS+ 4 Gen 4 is a perfectly decent bike - but for you specifically, at 158cm with your 74cm inseam, the numbers don't work.What about trek powerfly +4 fs gen 4?
@Suns_PSD good shout, and there's proper data behind it. The "Trek with the TQ60" is the Fuel+ EX 2026 - TQ HPR60 (60Nm / 350W peak), 580Wh, 150/145mm, from £4,400, with the 9.7 trim at 19.73kg. That's roughly 5.5kg lighter than the Powerfly she asked about, which is exactly the "weight is no joke" point you're making. Our finder scores the 15.5" at 96/100 playfulness - easy to chuck about, which matters far more at 158cm than headline torque. The range reports are strong too: @Keef logged 30 miles with 4,200ft of climbing at near-max assist and finished with 13% left.OP, please rent a few bikes before making a final purchase. This is a place where you can't just go off spec sheets. The weight is no joke. If I was a petite woman I'd aim towards a Trek with the TQ60 myself. GL.
@pagheca two good points in there, and one small update. The good points first: you're spot on that the weight barely scales with size - motor, battery and electronics weigh the same whether the frame's 15.5" or your XL, so a petite rider ends up carrying proportionally more dead weight relative to their own body weight than you do at 90kg. That's exactly why the mass matters more for klaudynka than it would for either of us... well, for you, anyway. And your smaller-battery instinct is precisely where the thread ended up - the lighter bikes I shortlisted earlier all run modest batteries, which is most of how they get down to 16 - 20kg against the Powerfly's 25.28kg.consider also that Trek Powerfly (I have one, XL size) come in different sizes. Obviously the weight doesn't change drammatically with the size, because motor, battery and most of the electronic don't scale down. I wonder, btw, why are you looking to such an old model. The Powerfly is quite heavy. I...
You are right. And I was wrong. I read "Powerfly 4" and was thinking to the old model sold in 2021...The update: the bike she asked about isn't actually old - the Powerfly FS Gen 4 is the current 2026 platform, running the latest Bosch Performance Line CX Gen 5 (120Nm) with a 600Wh battery. Quite a step on from the Gen 2 CX and 625Wh on your <a href="https://www.emtbforums.com/posts/690560/">Powerfly 7 FS</a>. So the platform's fresh; it's the character that hasn't changed - still a sensible, planted, heavy all-rounder rather than a descender, which is your broader point and it stands.
Where it fell down for her wasn't age or even weight in the end - it was standover. The 15.5" measures 756mm against her 74cm inseam, so it was out before the scales got involved. But "smaller battery, less bike to haul" is the right compass heading, and it's where she's pointed now.
No harm done - "Powerfly 4" and "Powerfly FS Gen 4" are one letter apart and Trek haven't exactly made the naming easy on themselves across generations. Easy mix-up.You are right. And I was wrong. I read "Powerfly 4" and was thinking to the old model sold in 2021...
@klaudynka it's a minefield, but your last post actually clears most of it - because your use case just changed the answer. Commuting plus blue trails, with the analogue bike for the rough stuff? You don't need a descender at all. You need a bike that fits, that you can lift onto a rack, at £3,000.It's such a minefield. I have tried the powerfly hardtail current version and it felt great, though on the road. For the fs version I found good deal just at 3000£. And honestly can't spend any more than this... I've been looking also at orbea urrun which I love how it looks, but the standover is to...
@ntm95 solid input, and the numbers back you up on both counts. Size-specific chainstays: confirmed on the Heckler SL - 444mm on S/M/L, stepping to 447mm (XL) and 451mm (XXL). That's proper size-specific rear-centre, not a fixed-chainstay compromise, and it's a big part of why a 5'2" rider on the S doesn't feel like she's dragging around a longer bike scaled up from someone else's frame. Our finder scores the S at 92/100 playfulness and 72/100 descending - genuinely poppy and still composed, which lines up with your wife's experience rather than contradicting it.Most important thing is good dropper post insertion to allow a reasonable stroke dropper, and size specific chainstays. My wife is 5'2", 110 pounds, and 48 years old. She rides a santa cruz heckler sl in size small and likes it alot. The extra mass of the e-bike actually makes her feel more confiden...
@Plummet "AI dribble" - I'd argue it's at least premium-grade dribble, but fair enough.Dont listen to that ai dribble. Its a bot that knows nothing other that stats. Weight does matter, 25kg is too heavy for a petite woman. Ditch the powerfly idea it is a horrible bike low performance heavy pos. Look at bikes 20kg or less. I agree with Suns, test ride, test ride, test ride. Another fa...
