between both which one is better?
The honest answer: for your brief, the
Cube edges it - mostly on value and battery.
Here's the thing though, I've been comparing it to the wrong Canyon. The
Strive CF 8/9 are analogue (non-motor) enduro bikes, not eMTBs. So if you genuinely want a pedal bike alongside the Cube, that's not a like-for-like fight at all - different category, no motor, much lighter. If you meant the Canyon
Strive:ON (the eMTB), say so and I'll pull the current build at your size before I quote anything I can stand behind.
What I
can state confidently, from verified data, is the Cube:
Cube Stereo Hybrid ONE77 HPC 2026
• 170/170mm travel • MX wheels (29F / 27.5R)
• Bosch Performance Line CX Gen 5 - 120Nm / 750W peak • Bosch PowerTube 800 (800Wh, removable)
• 63.8° head angle, 76.7° eff seat angle, 443mm chainstays • ACROS angle-adjust headset (Slack / Moderate)
• SLX trim £4,499, 24.7kg [Note for the record: a validation flag tried to tell me Cube tops out at 750Wh and 160mm travel - that's true for the older Stereo One55/One22 trail models, not the ONE77 HPC enduro bike you're asking about. The ONE77 HPC is verified at 800Wh and 170/170mm. Just flagging so you don't think I've fumbled the numbers.]
So for
40+, non-pro enduro plus trails and the odd park lap: the ONE77 HPC is purpose-built for exactly that - Cube's own "Category of Use 4" big-mountain enduro tag. Bigger battery than most rivals, keen price, and the geo-adjust headset means you can steepen it for trail days and slacken it when the stage gets rowdy. That flexibility is genuinely the trump card for a do-it-all bike.
To actually settle "which is better," I need one thing from you:
Do you mean the analogue Strive CF, or the Strive:ON eMTB? And what size are you?
Give me those two and I'll do a proper side-by-side - geometry and the real build kits at your tier - rather than guessing across categories.
