I ride a Cube stereo hybrid one77 hpc slx 800 2025.
How to set up the steep position on the across direction.
@Greg Watts
@Greg Watts
Both notches look to the frontSetting the ACROS angle-adjustable headset on your One77 SLX to the steep position is a cup-swap job, not a flip-chip — so it's a five-minute spanner session rather than a click. Here's the drill.
What the steep setting does
On the 2025 One77 it takes you from the slack 64.4° to a steeper 64.4°… correction — the steep position is the steeper of the two. The key thing is the eccentric headset cups have an offset bore, and which way the notches face determines whether the front end sits steeper or slacker.
How to set it
The reliable orientation our resident One77 owners use:
• Top cup: notch facing forward
• Bottom cup: notch facing rearward
That's the steep config — @Raptor confirmed exactly that arrangement, and @Rando_12345 backs the 64.4° figure for the steep setting on the 2025 One77.
The actual procedure
1. Pop the top cap and stem, slacken the stem bolts and lift the bar/stem clear (you don't need to fully disconnect cables — just rest it aside carefully).
2. Lift the fork steerer down a touch so you can access the cups. You'll likely need to press the eccentric cups out — they're a press-fit insert sitting in the headtube.
3. Rotate each cup to the steep orientation above, making sure the notches index correctly into the headtube — they only seat properly one way per setting.
4. Reseat the cups, refit the fork, set your headset preload via the top cap (snug, no play, bars still turn freely), then torque the stem bolts.
Stem bolt torque is typically 5–6 Nm for the Newmen/Cube cockpit on the SLX — but check what's printed on your actual stem faceplate and go with that, as it varies.
One heads-up
@Rando_12345 has noted the One77's geo is already "quite low and progressive" — going steeper raises the front a touch and quickens the steering, which some riders prefer for tighter, slower tech. If you find the BB feels low, the 140mm crank trick he uses helps with pedal strikes.
For the full step-by-step with photos, the owners' thread is worth a scroll — plenty of people have done this swap:
Hi, received my 2025 One77 SLX in size L on wednesday and took 2 very short rides on it.
I ordered the Bike from Bike24 due to the 15% sale, all in cost me €4300 with shipping. Easily the best deal out there for a Gen 5 bosch.
Bike came shipped in an enormous box with both wheels attached, only the handle bars needed fitting.
Bike looks good in real life, proportions are nice, my size L was 24.8kg with tubes in the tyres, no pedals.
Negatives:
- The battery cover is a pretty weak design, like a rubberized thing that just sits on top of the battery hole. I cant imagine that would...
- Rando_12345
- Forum: Cube
If you tell me which way your cups are currently sitting, I can confirm whether you're already in steep or need the swap.
Both look to the frontSetting the ACROS angle-adjustable headset on your One77 SLX to the steep position is a cup-swap job, not a flip-chip — so it's a five-minute spanner session rather than a click. Here's the drill.
How to set it
One heads-up
Negatives:
- Rando_12345
- Forum: Cube
Both notches forward means you're in neither the Slack nor Steep setting as described - that's an intermediate or neutral orientation that doesn't correspond to either confirmed position.Both notches look to the front
As Rando has mentioned, I found the slack factory setting a deal breaker for technical stuff, although great at full tilt. The fraction of a degree change to the steep setting is monumental and made the riding a beautiful thing . At some point you may find the headset bearing cups need grease to get rid of a rattle and a good thing to do at the same timehas noted the One77's geo is already "quite low and progressive" — going steeper raises the front a touch and quickens the steering, which some riders prefer for tighter, slower tech.
That's exactly the bit people underestimate, @Ndanger - on paper it reads as a rounding error, but a fraction of a degree at the head tube shifts where your weight sits over the front wheel, and on slow, steep tech that's the difference between confident and twitchy. The slack setting is built for letting the bike run at full tilt; you don't want it when you're picking your way through awkward stuff. Glad the steep config woke it up for you.As Rando has mentioned, I found the slack factory setting a deal breaker for technical stuff, although great at full tilt. The fraction of a degree change to the steep setting is monumental and made the riding a beautiful thing . At some point you may find the headset bearing cups need grease to get...
Good timing on the rotor question - cooking brakes on Alpine descents is a real problem, not just a perception one.I have been bike packing through the Alps and the downhill sections are cooking the brakes, I understand the fox 38 forks are rated for 220 mm rotors I could use them on the back as well, I assume that would void the warranty, I do want to give them a try if they could fit. Would I expect better the...
