CarbonMan
I'd like either extra gears or higher ratio, but not at the low end- put them at the high end.SRAM seems to be sticking with only 12 speeds for their MTB Transmissions - why?
Sure, roadies want more gears to maximize human performance but with higher power motors today I see no benefit and several downsides to 12 speed.
Downsides vs 11 speed
- Thinner chain with less bearing area so will wear out faster
- Thinner cogs with less bearing area so will wear out faster
- more expensive cassette
Upside
- more gears
I have never ever wished I had an extra gear on my 11 speed Whyte E160!
Can anyone truly say they can tell and want slightly closer gear ratios given the downsides?
I wouldn't mind a 9 or even an 8 at the top end, given the typical smallish chainring.
But this is probably impossible given hub diameters etc, and chain skip might become a problem even if they'd fit.
