2027 Orbea Wild LT Released - Avinox Powered
You need a reach adjust headset for a tapered head tube, ZS56/EC56, so external lower cup which will raise the front end ~8mm, the maximum reach adjustment you can have is 5mm, there's no space for any more than this.
If you consider the HA, a +5mm cup, will only increase your reach 3-4mm, so not much really.
The split in the chain stay at the main pivot is so this pivot is a "floating axle", to aid frame alignment, think pinch bolts on fork lowers, same lower pivot on Santa Cruz with the collet axle. As long as you tighten the pinch bolts to the specified torque, the will be no concern with strength.
About 10mm decrease in reach according to The Loam Wolf
Yes. That article explains it quite well and includes the affect of the height of the lower cup, IE net reach change isn't much, slacker HA, with the biggest impact actually being to stack.
So a -5 reach headset would end up giving me -10mm overall? I’m trying to get the reach down to 440-445mm overall, I’m at that weird build where I find most smalls too cramped and most mediums too long. The only brand that seems to make a bike that “fits” me out of the box is Atherton but then I’m having to wait until late September/early October to get a new bike.
Forbidden Dreadnought E S2 size is 445 reach.
Even a noob mechanic should know how to respect torque settings. And if they don't, there'll be plenty of other parts of their bike that they can f**k up!
Orbea's blue paper manual for the Rise is superb - it lists every bolt and gives you the hex/torx size, whether to use grease or thread lock and what it should be torqued to. Diagrams give you a break down of how the parts go together. Really good.
But on the Rise 25 it's basically impossible to get ever a small torque wrench with a short hex key inside the shock linkage to do the bolts up. It's not just the width, it's super tight against the seat tube as well.
On the Mk1 Rise the combination of crank and chainring shape meant a similar issue for the crank pinch bolts - I used an extension bar and long bit, but even then it wasn't in the bolt head perfect straight.
In the interviews I've seen with the Orbea designers they say that they moved from the Bosch CX motor to the Avinox because the smaller form factor of the Avinox allowed them to place the chain stay main pivot lower down in order to achieve the anti-squat they were looking for. But when you compare the two motors side by side I find it hard to see how this statement makes sense. Looking at the images below it would actually seem to me that there is more motor intrusion into the space where the main pivot is placed immediately behind/above the crank axle with the Avinox motor compared to the Bosch.
I almost hesitate to post these musings because I'm genuinely not wanting to start some kind of conspiracy theory here (I will leave that to the usual suspects on the forum :ROFLMAO:) and it may just be optics, but I can't see from the photos below how the Avinox motor is actually any better for positioning the main pivot where it is on the new bike.
Now add in the fact that they have - in my view rightly and courageously - chosen to decline the crazy power on tap from the Avinox and create a custom tune with characteristics that are not so different from the updated Bosch (both 750W power and 130 versus 120Nm torque) and it makes me wonder if they couldn't simply have created an "RS tune" with the Bosch motor. Clearly it must have been a commercially delicate decision to move away from their partnership with Bosch for their new bike, so there must be a good reason for the move. Maybe it really is about the pivot placement, or maybe Bosch weren't prepared to open up their firmware for a custom tune?
Ironically, whatever the reason, by choosing to use the Avinox motor with their RS tune they have created a conundrum for both Avinox fans and loyal Boschists alike. The fanboys will wail and gnash their teeth that the full 1300W isn't on tap by default (although they can create their own custom full power modes) and the Bosch lovers will wonder if they just have to move to the darkside because they really like the bicycle itself.
I personally really admire what Orbea have done with this bike and also with the Rallon RS, and I have nothing against the Avinox motors. Both Orbea and Avinox are pushing the envelope of eMTBs and that has to be a good thing. But as a European consumer I would prefer to give my economic support to a Spanish bicycle company using a German motor. As such I would have loved to see this bike launched with an RS tuned Bosch motor.
Having said all that, I'm still drooling over what a great bike this is with the Avinox RS! Chapeau Orbea!
There may be some merit to the idea that the pivot can be moved lower down on the Avinox motor, my rudimentary lines below show there would appear to be a lower crank position relative to the motor mounts.
That’s before you take into account any form factor size differences.
I like what Orbea are doing, I was very close to a Rallon RS as it’s my ideal kind of bike, but the price point did get me in the end!
I understand your other points about supporting European brands as well, but I guess that only works to an extent if non-EU countries are making your ideal package.
It’s truly genius marketing what they’ve done. The Avinox haters are all a little Noxcurious. They’ve been in denial stage the past couple years, but you can see on this very thread some of them considering the switch just due to a fake 750w cap.
Reasons for going Avinox: market demand.
Reasons for saying Avinox unlocked the perfect pivot location: lovely bit of marketing narrative 🤣
Maybe it really does offer the perfect pivot location vs bosch, but if the motor was out of favour, no chance they're moving to it.
Ultimate Goal=sell many bikes.
Maybe it really does offer the perfect pivot location vs bosch, but if the motor was out of favour, no chance their moving to it.
Has there been any rumors at all about what Bosch, and spesh have been up to? Im hoping Bosch doesn’t have a 5 yr gap to the gen 6. There’s gotta be something new and exciting coming soon that isn’t Avinox. I mean it’s nice seeing Avinox carving out their share right now but I do want to see how the other guys respond vs just power updates. I’m hoping the next spesh and Bosch motors are going to be insane (not just power but hopefully light/small/features and on par with at least m1 power).
You’re the man with the inside track, what does ‘sell many bikes’ look like?
What’s the Avinox market share for mid to high end EMTBs?
A niche within a niche if ever there was one.
I dont have any data at all, only anecdotal, and what I see and hear. But I'd estimate its hugely in favour of Avinox over any other motor system at the moment on mid to high end.
Maybe if we separated "hard core, in the know" riders (like most on this forum) I'd say that an extremely high percentage of riders would be choosing an Avinox powered bike over anything else at the moment, for their next ebike purchase.
Some of that is chicken vs egg - most new performance emtb's are Avinox powered, so the choice for anything else is being reduced as every month goes by.
I suspect there's a marketing element in the RS tune. Makes their bike stand out from the rest.
Did I miss something? What happened to the expected announcement about the Wild TR/ Bosch Version for 2027?
I allways assumed the thin down tube was a major selling point for the avinox too. I ride a 430ish reach ep8 decoy and want a new bike but not many make them that small. I would like a bump in power but not sure I need 1500 watts but would love that 700 battery. That thing is about 3 ponds lighter then my 720 now….crazy.
If I could find a CF frame in small that takes a 600/800 battery told myself I’d buy it. This bike is closest yet, yet everyone says rearend is too long for a small. But am I going to notice a 6mm longer chainstay then what I have now? Or the upper weight of a longer/higher battery? I’m a 56yr has been so maybe not.
I really like my decoy just wish for more power to keep up with my boys (13/15 on sane bike) and tanking so fast because I’m not in bike shape and be nice to be lighter too. Otherwise I have everything on my bike now I could want.
And do not unfer estimate the power of aesthetics. The form factor of the 800wh avinox battery vs the bosch one is so much more pleasing on the eye. And looks play a real role in the sale of high end bikes
Edit. Beaten to it by seconds lol
No.
Bosch will be in a tough place I'd imagine optics wise, and relationships with the perceived top brands (mondraker orbea santa cruz yeti etc) is cruicial, yet diminishing.
Bosch have enjoyed the premium high end market for years, and that is reducing seemingly every month. They do have a huge amount of lower end to mid segment bikes, trekking and touring bikes and they should be fine for a while - until Avinox (likely) start to take some marketshare from that segment too.
Spesh - They have to do something urgent right now and huge fundamental changes are needed. They must have blown a huge amout of Capex developing their latest turbo system. Bespoke software, batteries, motors aint cheap. If they dont sell, thats not good enough. Innovate or die. To me, Spesh is the most interesting of "what happens next" - They were dominating the eMTB world from 2015 - 2023 with hit after hit. But like anything in life these peaks only last for so long. Its cyclical. Look at anything in the world, it all has its time, and must have insanely good innovation, leadership and business savvy to succeed. Not many companies in the world continue at the top for long.
Now without being political here, China brands have sucker punched the entire world on pretty much anything consumer related in the past 5 years. eBikes,, Electric Cars, Batteries, Solar, Drones, Robitics, Phones, Semiconductors and AI which is the next "arms race" with the USA.
But what also goes hand in hand with their rapid success, is the public acceptance and perception. In March 2026 , in the UK, the China made Jaecoo 7 was the biggest selling car in UK as an example. What might have been perceived as a cheap, inferior product years ago is no longer the case. Chinese products = good value, advanced, faster moving, sometimes better than western stuff.
Folks are totally happy now to buy an Amflow, Teewing, Velduro or any other bike brand using the latest tech/motor that didnt exist 24 months ago. Taking nothing away from the hard work that the teams at those brands have made, they simple would not have been able to compete with a juggernought like Specialized 10 years ago. Now they can.
My honest 100% thoughts are that the brands of old, that enjoyed success though racing, suspension design, cool factor, brand history and nostalgia - their time is limited, unless they can really change fundamentally to what they can offer to the consumer. It doesnt take much to engineer a frame at all (compared to a motor / battery as an example).
Orbea have done the best job at making their product have point of difference between anyone else in the market, with their complete interconnectivity, that at the moment, no one else offers.
There is barely any intellectual property remaining in a frame or suspension design. There's really marginal differences between them all, and now, the motor, battery , electronic and tech are king, and that is what is selling bikes
If we take a look of recent past (let's say 10years), quickly we find:
TQ HPR120; Sachs, Bafang, but none pickup the pace.
Any powerfull motor, needs battery resources (wh) to be used accordingly.
Avinox, used a different approach:
Media / ++ information almost close to dotrination.
As in the past, most steered away from powerfull motors, the history will repeat, once TQ presents their new motor, and joins the moto:
"LESS IS MORE"
It won't suit all, but it will suit those that cycle and are pationate about cycling.
All very good points Rob and well put.
Maybe I'm a dinosaur heading for extinction but I have chosen to buck the trend for the numerous excellent Chinese EVs on the market and have just bought a Renault 4 electric plein sud (with sun roof). It's totally manufactured in France with french components including the batteries (although still with Asian cells at present). I chose it because it's a great car, but also because I like the fact that I can support French manufacturers and jobs. I think if we all just buy Chinese products because they're both cheap and good products we will soon find ourselves economically beholden to them because we will have stripped ourselves of home-grown options.
Just saying.
No.
But really, if Bosch doubled their power and opened up the top speed above Class 1 power limits (which they could do effortlessly) OR the Class 1 limits were vigorously enforced, what would Avinox have of substance over Bosch? A bit of looks with a corresponding loss in handling proficiency?
The motor system has strong merits, but to behave as if the Avinox is meaningfully functionally better than the competitors outside of looks and above Class 1 power levels, is dishonest imo.
People have referenced the Bosch Gen6 as if it would change any of this. The Gen 5 already offers best in class efficiency, reliability, quietness, serviceability, feature laden, etc.
Sucks to be Bosch right now. As a Western company governments and attorneys will happily fine and sue them out of existence all while Eastern companies are exempt from following the same rules.
OT: It's wild to watch the West so willingly squander their economic dominance in the pursuit of 'things'.
It’s somewhat surprising that some manufacturers managed to maintain a cachet for so long given Horst link suspension arrived in 1985 (and the patents expired in 2014), most frames are made in the same few factories in Taiwan, and so much of the value of a bike comes from Fox/Shimano/Sram and not the name in the down tube.
That seems to have narrowed even more this year - I’ve seen a whole load of Avinox bikes with the same fox factory suspension, bottom of the range SRAM electronic gearing, DT Swiss 1900 wheels and maxxis tyres.
    673K
