Amflow general questions and answers
I am having issues with sim card connectivity.
When I open the app i see 4g connection and then it turns off and it does not turn on.
(I am not near the bike and i’ve checked prepaid data status… it is using the plans data statistic)
I too am having issues. I'm in the US and tried a couple of different Sims and none worked - until an Avinox initiated update a few days ago and it worked! Then a couple of days later another update and it stopped working. Fun!
Just out of curiosity, Tim, which one ended up working (and then not) out for you?
I would guess that none.
We are missing a direct feedback on which network is the bikes TCU connected to cuz there are more possible networks and manual APN settings depend on the network that the TCU automatically picks.
This SIM feature is really underdeveloped at Avinox.
Good news, I was just tinkering around with the brakes and turned the PL on to take it for a spin... and 4G is working!
Since the last update both remote controller stopped working. Seems to be no battery problem because the led lights up when pressing a button. Main unit says paired but not connected.
I tried to unpair the remotes, switched off the main unit (pressing off button for 20 sec) and repaired them again. On the next day same again: paired but not connected. Bike is 2 weeks old.
Any idea ?
Hi Amflow Team,
I recently ordered an Amflow PX, and one of the main reasons I chose this bike was the possibility of using the official Avinox range extender.
Could you please share any available information regarding the release date and availability of the official Avinox RS600 battery extender for the Amflow PX?
Are you able to provide an estimated timeframe for when customers will be able to purchase it?
Thank you.
Last time Amflow Support posted in here was March. So I'm not sure they are watching the thread.
@Moderator . Might it be best to close it off, so people don't ask questions that never get answered, and just go direct to Amflow Support?
10 rides into garbaruk t-type cassette & m2s be like…View attachment 186771
The smaller the cogs the less distributed the load between the adjacent chain links leaving the cog on the upper side. This is a side effect of mostly riding small front chainrings which forces you to constantly ride the highest gear ratios. Maybe switch to 38T. And yes I am aware this reduces clearance but you have to compensate for a power transmission concept which is outdated by 150NM middle motors and the need to stuff in as many gears as possible and the resulting thin cogs and chains*.
*In this regard: special thanks to SRAM and its 1byX drivetrain invention and stupid X-DOME cassette design which won't allow you to just replace the most used cogs.
it needs a HG hub, but the SRAM XS-1270 cassette allows you to replace gears 8-12.
They did reply to the Refund thread last week.
We considered closing the thread, but it also seems to have become a general Avinox questions and answers thread.
Maybe that would be better served as a separate thread ? @Astro66 Would you like to make one and I'll close here with a link to that ??
No. It's fine to leave it open as a Q&A. As long as people understand they probably won't get a reply from Amflow, as the title kind of infers they will.
ok. I've changed the title. If they do start answering regularly again in the future, we can change it back, but presumably they're relying more on the standard Amflow Support system now it's bigger/busier.
Probably the best approach as they haven't responded to a DM I sent.
@Amflow_Support,
I already ordered an Amflow PR Carbon Pro in size L at my local dealer shop.
Regarding your external 600Wh battery, I saw on your homepage, that it will only fit for size XL and XXL, but not with size L.
Will it work with the damper from the PL Carbon modell and where/how can I get one with your original tune ?
THX in advance
Emes
I meant the update for firmware that was just released :D
  • Adds support for merging ride data to generate complete route.
  • Adds support for automatically switching assist mode to Boost during climbs.
  • Adds support for reversing start and end points of route before navigation.
  • Optimized navigation performance to support long-distance routes.
Version 1.4.0 • 151,7 MB
That's the app, not the firmware
    673K
