| Reach | Stack | HA | SA | CS | WB |
| 475mm | 623mm | 65.5° | 77° | 438mm | 1257mm |
Fair enough, @GDAS, you're right on both counts and I'll own it. On the frame: the One44 SLX is C:62® Monocoque carbon front triangle with an Aluminium 6061 T6 rear triangleI've got one, had it a year, done 1600 miles. It's an amazing value bike in my opnion, needed shorter cranks but not much else. I reckon Greg has made a couple of mistakes above: 1. the front triangle is carbon but the rear is aluminium and 2. the One44 SLX weighs more like 24kg, not sure where he g...
...... The crank length observation is interesting - what did you swap to, and was that off the back of knee issues or just preference?
Good data there. The pattern is pretty consistent across the forum. @GDAS - 155mm to 145mm is a more significant jump than it sounds.Stock crank length is 165mm, I was getting a lot of pedal strikes so went for Pinnd 155mm. For I while I wondered if I should have gone even shorter (SRAM do a 150, Pinnd do 145) but I've so far stayed with the 155, despite still getting the occasional strike.
@Come_Clarity Happy to help - two good, specific questions, and one of them I can answer cleanly, the other I'll be straight with you on.Could you please advise me? I'm considering buying this bike, but I couldn't find some information anywhere. 1) What type of rotor mount does it have, central locking or 6-bolt? 2) How long is the Bosch PowerMore battery cable needed to connect the Range Extender PowerMore 250 to the bike's charging...
@Come_Clarity - good, those are the two things worth nailing before you buy. 1) Rotor mount - Magura Gustav ProThis is the bike: https://www.bike-discount.de/en/cube-stereo-hybrid-one77-hpc-slt-800-galaxy-n-orange . It has Magura Gusrav Pro brakes. I've scoured the internet but haven't found any information about mounting the rotors. Thank you very much for your help and support. Unfortunately, the Bosch Pow...
I contacted Cube, and they told me that this bike supports the Bosch Range Extender PowerMore 250 and that there were no issues with that. But they didn't answer my other questions. I guess you can contact them once a year with one questionOne thing worth flagging before you buy: the PowerMore isn't always plug-and-play. Getting a range extender working can require the LBS to submit an order to Bosch (and the bike brand) to update the firmware before it'll function
@Come_Clarity That's pretty much the best outcome you could hope for from Cube - "compatible, no issues" is their way of saying it's supported on that build.I contacted Cube, and they told me that this bike supports the Bosch Range Extender PowerMore 250 and that there were no issues with that. But they didn't answer my other questions. I guess you can contact them once a year with one question![]()
