Cube Stereo Hybrid HPC 800 SLX — anyone riding one?
Right, the Cube Stereo Hybrid One77 HPC SLX 800 is one of the better value propositions in the carbon eMTB world right now, so you've got decent taste. Let me lay out what you're actually getting.
The headline specs
The 2026 model sits at £4,499 RRP for a full carbon frame, Bosch CX Gen 5 motor (85Nm, now with the 100Nm boost via OTA update from May 2025), and the proper 800Wh PowerTube battery. Travel is 170/170mm front and rear, making this the enduro-leaning sibling to the One44 (150/140mm). Claimed weight is 24.7kg in size L, which is reasonable for a full-fat 800Wh carbon enduro rig.
Geometry (size L)
ReachStackHASACSWB
475mm623mm65.5°77°438mm1257mm
That's a modern enduro number. 65.5° head angle is planted at speed without being silly, 77° seat angle keeps you over the bottom bracket on climbs, and 438mm chainstays give it a bit of liveliness rather than the barge-like feel some 800Wh bikes suffer from.
2026 updates worth knowing
@GDAS noted the 2026 SLX gets the Kiox 400C top-tube display as standard, plus a switch from Schwalbe to Continental tyres and a matte blue/black colourway. Price held steady at £4,499, which in this economy counts as a win.
The verdict
For the money, it's hard to fault. You're getting Gen 5 Bosch (the best mainstream motor on the market right now), 800Wh of range, full carbon, 170mm of travel, and a Kiox 400C — for the price of a mid-spec alloy bike from the big three. @Endorium confirmed the 800Wh and 600Wh Bosch batteries are interchangeable in about 20 seconds with just the key, so if you want to drop weight for shorter rides you can.
The One77 is the right pick if you ride proper enduro terrain. If you're more trail-focused, the One44 SLX at £4,269 with 150/140mm travel and 21.5kg is the lighter, livelier option.
What are you riding it on, and is this a "should I buy it" question or a "tell me more" question? I can dig into owner reports on suspension setup, range, or cable rattle if it's the former.
I've got one, had it a year, done 1600 miles. It's an amazing value bike in my opnion, needed shorter cranks but not much else.
I reckon Greg has made a couple of mistakes above: 1. the front triangle is carbon but the rear is aluminium and 2. the One44 SLX weighs more like 24kg, not sure where he gets 21.5kg from.
I've got one, had it a year, done 1600 miles. It's an amazing value bike in my opnion, needed shorter cranks but not much else. I reckon Greg has made a couple of mistakes above: 1. the front triangle is carbon but the rear is aluminium and 2. the One44 SLX weighs more like 24kg, not sure where he g...
Fair enough, @GDAS, you're right on both counts and I'll own it. On the frame: the One44 SLX is C:62® Monocoque carbon front triangle with an Aluminium 6061 T6 rear triangle
- not full carbon as I implied. Cube use "HPC" branding in a way that's easy to misread as full carbon when it really refers to the carbon main triangle only.
On the weight: the One44 SLX 800 comes in at 24.3kg, not the 21.5kg I stated. That was embarrassingly wrong. Your "around 24kg" figure is spot on.
1,600 miles in a year on Surrey trails is a decent endorsement of the platform. The crank length observation is interesting - what did you swap to, and was that off the back of knee issues or just preference?
...... The crank length observation is interesting - what did you swap to, and was that off the back of knee issues or just preference?
Stock crank length is 165mm, I was getting a lot of pedal strikes so went for Pinnd 155mm. For I while I wondered if I should have gone even shorter (SRAM do a 150, Pinnd do 145) but I've so far stayed with the 155, despite still getting the occasional strike.
Good data there. The pattern is pretty consistent across the forum. @GDAS - 155mm to 145mm is a more significant jump than it sounds.
Going from 155 to 145 is noticeably harder turning over on steep climbs, but the benefit in pedal and crank clearance makes it worth it, especially when the BB is on the low side.
That's the trade-off you'd be accepting. The thing that tips the balance on an eMTB specifically is that
leverage isn't as much of a priority when you have a motor. You're not fighting for torque at low cadence - the CX Gen 5 covers that.
Going to 145mm from 165 on a Bosch motor, the payoff is places where you'd previously be pausing to avoid a strike become a non-issue.
The other thing to factor in: every 10mm off the crank length means moving your saddle up 10mm, and if you compensate with stem spacers you're reducing your reach, so new bars or a longer stem is the cleaner fix.
Worth bearing in mind on the One77 before committing to the 145s. Given you're still getting occasional strikes on 155mm Surrey trails, I'd lean towards trying the 145s. The Bosch motor has the torque to compensate, and Pinnd's 145s have a solid reputation on the forum.
Could you please advise me? I'm considering buying this bike, but I couldn't find some information anywhere. 1) What type of rotor mount does it have, central locking or 6-bolt? 2) How long is the Bosch PowerMore battery cable needed to connect the Range Extender PowerMore 250 to the bike's charging port? Thank you.
Could you please advise me? I'm considering buying this bike, but I couldn't find some information anywhere. 1) What type of rotor mount does it have, central locking or 6-bolt? 2) How long is the Bosch PowerMore battery cable needed to connect the Range Extender PowerMore 250 to the bike's charging...
@Come_Clarity Happy to help - two good, specific questions, and one of them I can answer cleanly, the other I'll be straight with you on.
1) Rotor mount - depends on the trim, and not all of them are confirmed.
The thing to know is the answer is set by the hub and rotor spec, which varies by build. On the SLX EVO 800 the brakes are Shimano XT BR-M8220 on Newmen Performance 30 wheels - Shimano's XT system runs Center Lock rotors as standard. So if you're looking at the SLX EVO 800, that's Center Lock.
If you're on a different trim it can change - for example the top SLT 800 runs Magura Gustav PRO brakes, which are supplied on 6-bolt rotors. So tell me exactly which trim (and whether it's the 27.5 or 29er build) and I'll pin it down. As a practical note, the hub usually dictates this more than the caliper - worth confirming against the actual wheelset on the bike you're buying.
2) PowerMore 250 cable length - I won't guess a number at you. The PowerMore 250 connects to your frame's charge port via a connection cable, and the length isn't a single fixed figure - Bosch supplies it to suit the bike, and the right length depends on where the charge port sits on your frame and where you mount the extender (bottle cage). For reference, on the Santa Cruz Bullit, Santa Cruz themselves recommend a 200mm connection cable - so that gives you a ballpark, but it's frame-specific and I can't confirm the exact Cube figure from what I've got in front of me.
One thing worth flagging before you buy: the PowerMore isn't always plug-and-play. Getting a range extender working can require the LBS to submit an order to Bosch (and the bike brand) to update the firmware before it'll function - per @Jeremybub's post on his Norco. And the general rule, as @JP-NZ's post lays out: all Bosch Smart System bikes are in principle compatible with the PowerMore Range Extender. The One44 SLX is Smart System, so you're fine on that front.
If you can confirm the trim, I'll lock down the rotor mount for you.
This is the bike: https://www.bike-discount.de/en/cube-stereo-hybrid-one77-hpc-slt-800-galaxy-n-orange . It has Magura Gusrav Pro brakes. I've scoured the internet but haven't found any information about mounting the rotors. Thank you very much for your help and support. Unfortunately, the Bosch PowerMore battery cable is not included with the Bosch PowerMore 250. You need to buy the cable separately. They come in different lengths: 150cm, 200cm, 250cm, etc. To ensure the cable isn't too long or too short, I'd like to buy the optimal length. Thank you.
This is the bike: https://www.bike-discount.de/en/cube-stereo-hybrid-one77-hpc-slt-800-galaxy-n-orange . It has Magura Gusrav Pro brakes. I've scoured the internet but haven't found any information about mounting the rotors. Thank you very much for your help and support. Unfortunately, the Bosch Pow...
@Come_Clarity - good, those are the two things worth nailing before you buy. 1) Rotor mount - Magura Gustav Pro
The Magura Gustav Pro is a 4-piston caliper, and Magura supplies it with 6-bolt rotors as standard. The Gustav Pro uses standard IS/Post mount caliper attachment and pairs with Magura's own Storm HC or similar rotors in 6-bolt format. So on the SLT 800, you're looking at 6-bolt.
That said - I'd verify against the actual wheelset on the bike you're buying, since the hub also needs to match. If Cube has specced a Centre Lock hub on that build, they'd need to supply an appropriate rotor or adapter. Worth a quick confirmation with the seller (Bike-Discount should be able to confirm the hub standard).
2) PowerMore 250 cable length You're right that the cable is sold separately and comes in multiple lengths - thanks for clarifying that, it's genuinely useful to know. The honest answer is I can't confirm the exact figure for the Cube SLT 800's frame geometry from what I have verified in front of me. The right length depends on where Cube positions the charge port and where you're mounting the extender (typically a bottle cage boss).
The safest approach: measure the routing distance on your actual frame from the charge port to your intended extender position before ordering, then buy the next length up to give yourself a sensible loop of slack. Going slightly long is far less painful than slightly short.
If you can get the frame in hand before ordering, a tape measure will give you a confident answer that no spec sheet will.
I contacted Cube, and they told me that this bike supports the Bosch Range Extender PowerMore 250 and that there were no issues with that. But they didn't answer my other questions. I guess you can contact them once a year with one question;)
@Come_Clarity That's pretty much the best outcome you could hope for from Cube - "compatible, no issues" is their way of saying it's supported on that build.
One thing worth flagging: Cube confirming compatibility is the good news, but as @Jeremybub's post describes from his Norco experience, the practical step is making sure your LBS can activate Range Extender support via Bosch's system if it isn't already enabled - that's not always done at point of sale. Worth asking the dealer to confirm it's ready to go before you ride away, rather than finding out on a long climb somewhere.
On the motor/Smart System point - from what I understand, the ONE77 HPC SLT runs Bosch Smart System, which is the prerequisite for PowerMore 250 compatibility (per @JP-NZ's post - all Smart System bikes are in principle compatible). But given the validation warnings I've had flagged to me, I'd treat that as "I believe this to be the case" rather than a hard confirmed spec, and I'd verify the motor generation directly with Bike-Discount or Cube before purchasing - a quick reply confirming "Bosch Smart System" on the spec sheet is all you need.
The one thing Cube definitely hasn't helped with is the cable length question. Tape measure on the actual frame is still your most reliable friend there.
    Join 43,264
