Advice for new Amflow owner
Swervedriver
Hi, I recently got my first emtb an Amflow PX Carbon Pro.
I’m in the UK in an area where we don’t have the biggest hills so for our “downhill” runs we have to make the best use of the elevation. This means quite a lot of our jumps are on a traverse without a huge amount of slope to help with momentum.
The problem I’m having is as soon as I hit the 15.5 mph limiter its feels like I’m riding through treacle so three or four bike lengths from the take off I’m struggling to get the speed to clear the gaps I could get over on my analogue bike.
Are there any settings that I can adjust or a good custom configurations can help with this? Or is there something that I need to adapt in my riding.
I bought the emtb mainly so I can get more downhill laps in on my local trails and although I’m having fun going uphill I’m not having so much on the way down and some trails now just seem impossible as I cant clear the gaps.
Any help much appreciated.
Yup you need to get a VPN and pair the bike to your phone via the US. This will let you select 25, 32 or 45 km/h as max speed. Just unpair your phone and forget the device in the blue tooth use a VPN set via the US, or New Zealand or Zhong Kong for a 45km/h max.
See attached YouTube how to video.
Yep. I had this same issue of casing so many jumps, because the limiter cut in just as the approached the takeoff, causing your takeoff speed to be incorrect. I have a 32kph limit I can select when I'm riding jumps all day. Apparently I'm a terrorist when I'm using it and not breaking my neck. But we all have our crosses to bear ....... 🤭
See this thread. De-Restriction should only be discussed inside the De-Restriction area of the forum.
Thanks both, I had seen about the de-restricting I just wanted to check to see if we had any other options before going down that route.
It’s interesting that this doesn’t get mentioned on more reviews. On my ordinary bike you’re working out speed for jumps based on feel not with specific numbers in mind. I had no idea going into this that the limiter was going to be this much of an issue. It’s not like I want to go hooning round on footpaths or the road.
It would be OK if pedalling past the limit didn’t have so much drag but you’re getting the eqivalent of engine braking just at the wrong time.
Cheers
Cheers
Is it actually "engine braking" or is it instead loss of assistance to overcome wind resistance and bike weight/tyre drag at the cutoff speed?
I’m not sure exactly what it is.
I did experiment riding downhill on a paved surface with the motor off where you would think the weight would help but it was significantly more draggy/slower than my ordinary bike that is 15lbs lighter and also on soft compound tyres.
I think the brain can get fooled by the input as I notice the same thing just reducing power on a hill.
Try riding up a long hill in trail mode for a couple of minutes and then go to Turbo for a couple of minutes Now go back to Trail mode and the ride will 'feel' much harder than it did when you started because you got used to Turbo.
IMO the ability to circumnavigate the limiter is the biggest incentive with the Avinox system. The power is not even a consideration.
Our limit is 25kph and that ability to go a little bit quicker when you need it without that dead stop at 25kph makes a massive difference.
Yep you don’t need a whole lot more most of the time but it can turn a trail that difficult to ride on an Emtb into one thats fun again.
Bosch EMTB gives 340% help, Avinox in Auto is 400%, there are still 3 modes higher. Trail, Turbo and boost.
I ride in Auto, its more than enough, compared to my Bosch, Auto on the Avinox feels more help than the Bosch in turbo.
