Crestline RS 181.2 thread – builds, reviews, technical info
It looks like if you get the wolf tooth resolve dropper you can do 160 slammed.
I actually have a 160 resolve that I’ve been meaning to try. It’s actuator part is longer than the oneup so I figured I wouldn’t be able to insert it as much as the oneup, but I didn’t actually try it
Oh ok. Idk I was just going off their website insertion depth which I thought included the actuator but maybe not. Hope it works out though!
coming from a kenevo sl with reduced insertion depth, now on a velduro, nothing beats deep insertion depth. 240mm drop is a lot better than just having a 210mm with travel reduced to 190mm...
i'll never ride another bike with a shock tunnel
Preach short king!
So I flipped my bike upside down to take off the rear wheel and change the tire. When I did, I saw this thing sticking out of the skid plate slot on the bottom.
I tried to grab it to see what it was but it fell inside. So I took the skid plate off and fount this.
I thought it might be a plug and go in this hole in the bottom of the motor. But it’s too big to fit in the hole which is threaded. Does anyone know what it is or where it goes? And what if anything goes in the hole on the bottom of the motor?
Wasn't sure this day would ever come, but they are in stock now...
Just scooped up the "shuttle guard" to cover the hole left in the ridewrap kit!
Hope this helps others in the same dilemma.. you are cordially invited to chuck gravel onto the frame!!
