Atherton S170.E Dyf-E bike coming soon...
Does anybody know whether the Fox 38 Factory supplied on the S.170E.1 is a 180mm post-mount fork or the new 2026 200mm post-mount chassis?
I’m planning to fit larger discs 223mm, so I wanted to confirm whether I need +43mm or +23mm adoptor for the front.
I'll probably go 203mm on the rear - does anybody know the direct mount of the rear triangle?
Cheers
Cheers
Just heard back from Atherton on this, incase anyone else is wondering.
FYI -
The fox 38 is a 203mm direct mount and the E-bike is 203mm. To go up to 223, you'd need a standard 20mm adapter.
FYI -
Did this change for the new 38? My 2025 Fox 38 is direct mount for 180mm rotors.
It appears the fox 38s (2027) has a PM200, whereas the earlier models had a PM180.
I double checked it and noted:
Ref -
29-inch forks now use a PM200 rotor size (before it was PM180), while the 27.5-inch model still uses a PM180. Both have a maximum rotor size of 230 mm.
And
Ref - https://ridefox.com/products/my27-fox-38-factory?utm_source=chatgpt.com
ROTOR SIZE200 DIRECT POST MOUNT, UP TO 230 COMPATIBLE
    668K
