Forbidden DreadNought E
Back in the day I rode some pretty hairy stuff on the old Orange G3 in my sig (and on other old school 26ers MTBs) for sure slack angles and big wheels make going fast down techy stuff easier but we just went a little slower. If all you want to do is point it down hill and hang on then current geo is fine but for 'proper' riding (i.e. going up hills too 😂) it's way too sluggish*. Geometry that only starts to work above 20mph is inappropriate for 90% of riders but like many sports the influence of the top 10% racers is all pervading and we get sucked in by the hype.
* My one serious complaint about my Rise (and the Urrun I had before it) is the super slack head angle, both would be better with another 3º or 4º but all MTB/eMTBs have this dumbed down handling these days. I predict that in 5 years time we'll be seeing eMTBs with 70º head angles and 1050mm wheelbases on 27" wheels as being the 'next new trend'...
I'd not hold my breath. It's been my experience that the vast majority of people want to go faster, not slower.
And modern geo, particularly forbidden's, is hardly aimed at sledding down a hill. It's specifically aimed at being able to slap the crap out of corners at speed.
Back on topic, on an e-dreadnought related note: with some nobl tr37 carbon wheels, specialized's new radial gravity casings, a 600wh battery, and some carbon bars, my s3 t2 now weighs 48.7 pounds. Not bad.
Nice! Photos please
Can you tell me how many tokens are included with the Tier 1 Zeb Ultimate? I'm not using the full travel, and I'd like to remove any tokens if there are any.
I will take a look today as I am curious as well. I was using all my travel and have increased the air pressure but may also add a token
Hey ntm95,
I'm in the same boat as you going light. Got some couple photos? Curious about the rest of your parts - stock t2?
Also how's the 600wh treating you? How long are your rides / power mode? etc.
Waiting on my t4 S3* which I am going change out pretty much swap out all the parts from my crestline S180.
Hey ntm95,
Waiting on my t4 S4 which I am going change out pretty much swap out all the parts from my crestline S180.
I'm away from home for a few more days for pics, but as for parts, pretty stock other than some oneup carbon bars and a leatt stem.
I've got assistance slightly turned up in eco, and turned down a little in auto. Use those most of the time.
Comparable numbers to my bosch cx 5, around 1200 meters of climbing. Usually just plug in the fast charger at lunch time and it's a 2000-2400 meter day.
I'm trying to target sub 48... same wheelset as you, but different suspension - Mezzer Expert v2 (maybe move to a v2) and a Hover Monocoque. However I will need to figure out if I can switch the 800 to 600.
Hey there ntm95, I am wanting to remove the motor and battery but haven't seen any good instructions for this. Was the process pretty easy? Anything that you followed to do it?
I think that I have a cable rattle (maybe the rear brake line) and would love to take things apart and see if I can sort it out.
Thanks for any info,
Daniel
Daniel
Hi Daniel,
I just removed the front motor bolt, loosened the rear slightly, and spun it up and back.
    668K
