Shorter cranks for a Bosch SX system. Which offset will be compatible, and general sense check!
Rockhopper70
Calderdale
I’m getting quite a few pedal strikes on my bike, a Canyon Neuron On:Fly, which came stock with 170mm cranks.
I’m wondering about going shorter, as short as 155mm which seems to be a good length to encourage a decent cadence, which is what the SX system needs.
Hope are the boutique choice, a bit speedy, but they come in two offsets, standard and narrow, and the latter seems to be the correct choice. I’ve also seen the SRAM X0 155mm for around £100. They have no options for offset, so are they likely to be narrow, or standard?
OEM on Pivot Shuttle SL/AM is 160mm Praxis eCranks; 160mm RaceFace ERA on Transition Regulator; both work fine with Bosch SX. When I dropped to a 155-mm crank on a different eMTB, I felt less stable off the saddle while riding chunkier terrain, and switched back to 160 mm.
First test ride out today with the X0 155mm cranks. The riding didn’t feel noticeably different but there was definitely fewer pedal strikes, even none that I could notice. Went across my usual rocky moonscape route to check and all good. Definitely a worthy upgrade.
First test ride out today with the X0 155mm cranks. The riding didn’t feel noticeably different but there was definitely fewer pedal strikes, even none that I could notice. Went across my usual rocky moonscape route to check and all good. Definitely a worthy upgrade.View attachment 185205View attachment 185206
yeah, I can't tell the diff between my 155s and my 165s except far fewer pedal strikes and a lot more confidence when I need to pedal over roots and rocks.
    670K
