No Boost on my new M2s
bikedrd
US
A bunch of us on the RS 181..2 Crestline forum are having the same issue, so I thought I’d reach out to the Avinox sub.
When we use Boost, the motor cuts out. Happens in both settings - with and without Boost Local Enhancement. Boost reset, etc.
Anyone know what’s up?
Amperage limit as the battery sags in voltage maybe ?
Is it when it's particularly cold out, or the battery is in a lower state of charge ?
Unfortunately, none of those issues. Brand new, nice day, full charge.
I have the same thing happening. I have reached out to Troydon and Avinox but have not received a response. Please do the same!
Crestline just got back to me and says it’s a known issue and may need an update. Turbo at full power supposedly works the same as boost. That is the recommendation for now.
I opened a ticket to Avinox. I think it's just a software bug, and they should be able to patch it. The bike works perfectly in Turbo with max settings.
Does Eco and Trail Modes work like they should?
They do, but boost does not work in any mode. One other odd thing I noticed is that under custom modes I cannot change the wattage of trail mode but I can in all of the others. It just appears as a blank window if you click on change?
That was my thinking,if your in turbo at 1300watt how can you get boost?
Rizzle,a member on here states that his bike is working ok.
You would get 1500w with the 700 battery. ;) When I initially discovered this I had already dialed down my settings a bit. The bike is a handful with full beans but I would still love to have it on the button.
You would get 1500w with the 700 battery. ;) When I initially discovered this I had my already dialed down my settings a bit. The bike is a handful with full beans but I would still love to have it on the button.
Not got to ride mine yet
can anyone show me a picture of an obstacle you can only clear with 1500w of boost but not with turbo at 1300w?
I believe that's not the issue.
The issue is boost isn't working in any mode, even lower power settings.
14 buses at least.
Everything I’ve heard is you need the 700 battery for 1500w boost. I think it’s amflow only. I could be wrong but velduro have the same issue.
    Join 43,130
