I know people who have ridden this new motoThis would be an absolute disaster, but i suspect there will be 3rd party devices developed if they do.
I'll be kicking myself for turning down a preprod velduro last year if this happens.
View attachment 180337Reliable sources indicate that it will have a 700Wh battery, ultra-fast charger, and a 50km/31mi extension cable.
I hear they have a Solar power back pack , that Auto charges while rideing.View attachment 180337Reliable sources indicate that it will have a 700Wh battery, ultra-fast charger, and a 50km/31mi extension cable.
I noticed the Mondraker Zendit has 2 bottle cage mounts which seems like a big clue to me!Someone posted that they heard there would be coming on one of the previous posts.
I think if they are releasing a bike with 700wh fixed battery and 1300w of peak power then there will almost certainly be a range extender but perhaps not and they are putting all their eggs in the fast charging basket.
Absolutely! 940wh. Clean, simple solution without external battery, for most should be enough. + possibly 300wh extender.I noticed the Mondraker Zendit has 2 bottle cage mounts which seems like a big clue to me!
Agree with some posters above that even as a frequent double big battery user, a 600Wh extender seems a bit unnecessarily large (assumption that it will weigh a bit over 2kg and take up most of the space where a water bottle would go). 700Wh+300Wh would probably be a pretty great setup for most people, especially if you can fast charge both in parallel easily.
Personally, I think the main thing that would significantly improve (some of) my rides is a 940Wh battery, while still having access to a water bottle.
Buy the spider. AUD$59.I placed an order and I think it will arrive in about two ~three weeks.
Apparently, Amflow PX uses a spider-free chainring
I want to change to 36T chainring.
Where can I get compatible products?
Im pretty sure 600wh RE is fake gossip.the problem with the 600Wh extender is that almost certainly will not fit on M size... bottlecage 250/300 would be also for me a better solution
Really don’t like the colours![]()
That's not a problem, lol.Really don’t like the colours![]()
Fair point. Looks like it’s coming standard as mullet too which is a solid upgrade as well.I’d wait, $1500 for new geo, more power and potentially new batteries? Seems cheap.
It could actually make sense, maybe mounted at the front? Around the head tube? That would also explain that screw I couldn’t figure out in the photos, and the hole you can see in the pictures of the downtube on the Ekano with Avinox.Was chatting to a dealer the other day who reckons he’s had it confirmed they have a 600 range extender in development. It will use bottle cage mounts but won’t fit the medium frames, long and thin are the words he used.
If it has to be long and thin and doesn’t fit inside the frame triangle, the only logical place seems to be right there at the front. The only doubt I have is the possible exposure to impacts from rocks.
It would also be quite ingenious, because it would still allow you to keep a water bottle and the battery weight would remain lower, with a better center of gravity.
View attachment 180615@Gaba83 : Where did you get this picture from?
What are your guy's thoughts on pulling the trigger on the Amflow PL Carbon (non-pro) from N+1 bikes right now? Is it silly to not wait to see what the new models officially look like? I just don't want to miss out on the $1500 off the XL, seems like with Amflow selling out that N+1 could sell out soon too.
The base model utilizing S1000 shows that wireless shifting will be available on both.Would definitely wait. Plenty of confirmed upgrades just from the photos.
Also is it me or the new base model gets standard autoshift? From the leaked website specs, it says AXS pod shifter for the base one.
Or we climb steep mountains and really remote trails.I'm continually amazed that range extenders completely dominate every Avinox topic on every internet forum. You guys must all have butts of steel!
That's the screw for the internal 600wh battery...It could actually make sense, maybe mounted at the front? Around the head tube? That would also explain that screw I couldn’t figure out in the photos, and the hole you can see in the pictures of the downtube on the Ekano with Avinox.
Teewing Flux might suit better?i am disappointed by these new amflow offerings. the same poor frame design with clevis shock, limited dropper length and long seattube. why didnt they bring a real enduro bike with a 65mm stroke rear shock and a better frame design? i guess the one good thing is i wont have to spend a bunch of money on a new bike this season.
i still fail to see the reasoning behind full power trail emtbs. i just think the enduro platform makes so much more sense for full power. the average riders will get a safer more forgiving bike and the advanced riders will have geo and travel they need for fast/aggressive
