Well, unno did by accidentNo one is gonna show any proof of any new Avinox stuff considering the strict NDAs that are in place.
Genuinely wish I could give you a satisfying number, but I don't have verified data on a new intermediate Avinox battery capacity. What I can tell you is that every Avinox bike in my database runs 800Wh (with the Rotwild R.EX 900 actually nudging that to 864Wh), so if there's a new format battery slotting in somewhere in the range, it's not something I have confirmed specs on yet.hey @Greg Watts What is the watt hours size of the new avinox battery to run alongside the 600wh and 800wh that @Zimmerframe is referring to?
And then got absolutely shafted for it.Well, unno did by accident![]()
I can't believe I missed whatever they said especially as I am on their mailing list and Facebook group etc. If anyone can PM me what was said that would be greatAnd then got absolutely shafted for it.
The bosch 800 weighs 300g less than the 750wh...Because the largest existing is 800.
The newer largest is bigger than that.
But there's a new format battery due out, which is in this bike. (This has all been discussed in detail and seemingly forgotten)
I can't see in turbo you getting 1400m plus climbing out of a 600wh. With weight of 75kg.The bosch 800 weighs 300g less than the 750wh...
There is no new format dji battery due until 2027. Given the weights atherton has advertised, this couldn't be anything but a 600wh battery. And in terms of range, my very fit wife can get more range out of a 600wh than I can out of a 800wh, so pretty subjective comparing such things.
I cannot see that though. Especially when they are comparing range to a Bosch 750wh, it has to be bigger than 600whI can't see in turbo you getting 1400m plus climbing out of a 600wh. With weight of 75kg.
If it was a 600wh, me and my mates that have ordered one would be cancelling them
Possibly they've done a proprietary battery, but that has ended in tears for most companies to try it.I cannot see that though. Especially when they are comparing range to a Bosch 750wh, it has to be bigger than 600wh
But the same person rode the Bosch, and got the same range. It clearly says they tuned both motors to the same power, output etc so it has to be bigger than 600whPossibly they've done a proprietary battery, but that has ended in tears for most companies to try it.
I'd think more likely someone detuned the hell out of turbo mode, shotgunned a couple redbulls, and let it rip.
The logic is it has the same range as a Bosch 750wh. So it has to be very close to it in wh. Especially when they made an effort to state they tuned the DJI to match the Bosch outputLots of the Amflow videos, Will Greenfield, MBR, etc have around 1400m, Sam got 1650 with the 800Wh in Turbo, it's very subjective. I think the Wild came with the 750Wh just for Aesthetics, that 800 bosch is a bit chunky. I don't think there's any logic behind the comparison to a 750Wh other that that's what they had
No, I suspect 740 ish. Then a larger 900ish for other bikes.I don't think you'll be cancelling it due to the battery size, just a shame they can't fully announce any real numbers yet.
The orbea wild still runs a 750wh battery with gen 5 motorALso they compare to bosch gen 5 with 750wh? I thought the 750wh battery was a gen 4 battery?
ah, so gen 5 motor with gen 4 battery. seems an odd mix
I think it's more down to that being what they had before. The current Wild still uses the 750 with the gen 5 so they could have a thinner downtube. The 800 Bosch is chunky. It could easily be a 700 with a slighlty more efficient motor or an 800Wh with less efficient motor we'll have to wait I guess. It does seem a lot less likely that it's a 600 which is good for meThe logic is it has the same range as a Bosch 750wh. So it has to be very close to it in wh. Especially when they made an effort to state they tuned the DJI to match the Bosch output
Good to know. I had wrongly assumed all gen 5 motors had to use the new batteries.The orbea wild still runs a 750wh battery with gen 5 motor
Proprietary then ?But the same person rode the Bosch, and got the same range. It clearly says they tuned both motors to the same power, output etc so it has to be bigger than 600wh.
There are bigger batteries due this year from Avinox but I was under the impression it would be later in the year.Proprietary then ?
This isn't a good thing, that means it'll either be heavy, or prone to spontaneous combustion.
Or perhaps the information I'm getting from behind the curtains is wrong, and dji is a year ahead of schedule with the 65a's. Which would be great, and likely a deathblow to the other power system manufacturers.
Yup, with the 65 cells.There are bigger batteries due this year from Avinox but I was under the impression it would be later in the year.
"Apparently, in 2026, only customers in the UK and EU will be able to order eMTBs from Atherton, with global distribution planned at a later date."
I was told sameThere are bigger batteries due this year from Avinox but I was under the impression it would be later in the year.
As long as you pay the fines and potential lost business because of breaking a legal contract ?Feck me, I can't believe all of this bollix over an emtb motor. Anyone would think it was special to a 'war effort' and needed to be kept hush, hush for fear of losing the war.
What a load of tosh, just say what it is and be done with it. Embargo, my arse.![]()
I'm not having a go at the likes of Atherton and other bike manufacturers here, just Avinox as it's an e-bike motor, not 'The Precious'. The whole embargo thing is ridiculous, anyone would think Avinox is being run by 8 year olds in a school playground.As long as you pay the fines and potential lost business because of breaking a legal contract ?
