slickrock
- Thread starter
- #121
It's true that HP limits chain growth because the top chain is basically in line with the swingarm if the idler is at least at the swingarm pivot or on the pivot itself (i.e. iTrack). Unfortunately HP does little if nothing for bottom chain line, so it can still flail around, albeit the effects of this flailing is less critical than stopping the behavior on the top chain, but it is still there. One way to quell the bottom chain whip is to use a static chain tensioner hugging the the chain ring from the underside, like what the Slash+ uses. PB has always been fond of that bike and part me wonders if its because it's both a HP and also has the bottom tensioner - basically a good chain taming setup.I guess I was under the impression that a true high pivot (these are really mid-pivots we are discussing in this thread) that the entire point was that you could have high anti-squat AND no pedal kickback just because the distance from the idler wheel to the rear axle did not grow under compression, aka no chain growth.
As you are familiar (i'm saying this more for other readers), I'm still of the belief that a lot of people sense with kickpack is a large part to do with the chain whip than actual pedal kickback (both from rotational kickpack and suspension activation / chain lengthening), especially on downhills where you are on the lower cogs, where the chain is slackest and the derailleur clutch the weakest. Anything that attends to this dimension of the kickback effects is a step in the right direction. HP bikes attend to about 65% of the problem, but can still leave some on the table, hopefully addressed by other aspects of of the bike setup and specific design.
