Nice, thanks for taking your time to do this, really appreciate it.
Hate to say it, but the Rogues downtube is nearly the same thickness as the old Levo's in these pics, not taking into account scaling and sizing differences. Of course the same can't be said if the comparison was to the latest gen Levo. Still, the Rogue is a an Avinox steed, so there should have been no comparison and would have been silly if the Levo was compared to, say, an Unno. I'm not trying to harp on the bike's aesthetics (I have a deposit on one), and while I really like the bike's appearance overall, I have a gnawing feeling that the downtube could have been made slimmer, as has been afforded with other bikes that use Avinox's slender battery system. OTOH, this this might be some optical illusion, as I've yet to see any Avinox bike in the flesh.
Have you seen it in person? What ebike you ride now?Hate to say it, but the Rogues downtube is nearly the same thickness as the old Levo's in these pics, not taking into account scaling and sizing differences. Of course the same can't be said if the comparison was to the latest gen Levo. Still, the Rogue is a an Avinox steed, so there should have been no comparison and would have been silly if the Levo was compared to, say, an Unno. I'm not trying to harp on the bike's aesthetics (I have a deposit on one), and while I really like the bike's appearance overall, I have a gnawing feeling that the downtube could have been made slimmer, as has been afforded with other bikes that use Avinox's slender battery system. OTOH, this this might be some optical illusion, as I've yet to see any Avinox bike in the flesh.
Venn diagram should answer the first question:Have you seen it in person? What ebike you ride now?
check out Bike comparison: Velduro Rogue 2026 vs Specialized Levo SL 29 2023 you can change the specialized bike easily if I've not picked the correct one and sizes.Nice, thanks for taking your time to do this, really appreciate it.
I am not a fan of different size rotors front and back. It's true that a bigger rotor can generate more braking power, and you can use that better on the front while at the back the wheel might already be locked up.I would for sure go up to 220/223 Front at least. Rear being 200 is fine imo.
answered questions I didn't have ... but good info thanks. If I'm 10-15kg heavier than you so bike and me will be circa 113kg then maybe 223mm is my way.I am not a fan of different size rotors front and back. It's true that a bigger rotor can generate more braking power, and you can use that better on the front while at the back the wheel might already be locked up.
But braking power is usually not an issue, even at the front. Especially not with 200/203 rotors. You will most likely have no trouble locking up your front wheel or go over the bar, depending on grip, any time you want.
What you really want the bigger rotors for is mass and surface area, to absorb and dissipate heat on longer descents and therefor avoid fading and other nastiness that comes with overheated brakes. And I found that I use the front and rear brakes about the same, or the back even a tad more. Thats also visible in brake pad wear. I usually change pads front and back at the same time, but the back is just a little more worn than the front.
So, I would recommend you to go the same size both front and back. What size exactly depends on your use case, weight and also largely on the design of the disc.
Discs with many small holes (BrakeStuff Push, Intend Massive for example) can absorb a lot of heat and dissipate it also very quickly. Here you can size down. The reward is a little less (but still more than you need) initial brake power but great consistency and controlability during all riding conditions.
Discs with large cutouts (Ashima ultralight, as an extreme example) give you lots of initial braking power if you go big diameter, but are not well suited to longer descends. They overheat quickly.
Somewhere in between are discs like Galfer Shark or Trickstuff Dächle.
Overall its not such a good idea to try and save weight on discs if you want to go down for longer periods of time. Cutting many small holes in a disc is expensive (long time in the laser machine), but gives great rewards in terms of heat dissipation on long descends.
That said, I (~75-80 kg with gear) opted for 203 Galfer shark front and back.
Sounds about right. But don't just look at diameter, look at the design also. That makes a bigger difference imho.answered questions I didn't have ... but good info thanks. If I'm 10-15kg heavier than you so bike and me will be circa 113kg then maybe 223mm is my way.
my intention is Galfer SharkSounds about right. But don't just look at diameter, look at the design also. That makes a bigger difference imho.
save your money and go trp rs05emy intention is Galfer Shark
Larger rotors on the front are not all about power and heat dissipation. It's also about more breaking control.I am not a fan of different size rotors front and back. It's true that a bigger rotor can generate more braking power, and you can use that better on the front while at the back the wheel might already be locked up.
Most of my riding is on a 70mtr vert hill. 220 is the ducks nuts and does not need heating up to be powerfulLiterally every single vehicle short of a farm tractor uses larger front brakes than rear, for a reason. Weight transfers, the front end has way more traction and therefore higher braking power needs.
My experience has been those identical sized rotors on a bike, makes the rear feel much more powerful just because it locks up super easy in comparison to the front.
I would not mind experimenting with maybe identical sized rotors but choosing a pad compound that has less grip in the rear. I rarely have the elevation to overheat my current 200/ 180 set up, so the concern would be that a 220mm rotor would never get any heat into it to work fully. Plus... weight weenie...
and some dh racers like troy brosnan have it the other way aroundLiterally every single vehicle short of a farm tractor uses larger front brakes than rear, for a reason.
When did you order?ah, perfect, no worries for me then. Thanks.
But that was really the last thing I needed to sort out before my frame arrives. All necessary parts for the build are either old ones I have or were bought over the last weeks from various used part sources on the web and are already here. Everything I will buy new is selected and sits in the shopping cart of my favorite shop and will be ordered when the delivery date of the frame is only a couple days out. No need to have stuff laying around here and waste time of the warranty.
But now I have nothing more to do. On top of that I got the info yesterday that the second shipping container going to Germany (I was too late to get a frame out of the first one) is likely going to be delayed by a few weeks until mid of May. That is almost four month from now! What am I going to do?
In my desperation I have started to look for titanium screws to replace steel screws on the parts that I already have. That's not going to make one bit of a difference for the performance of the bike, but, well, it had me occupied for a while. But I found a replacement for every screw where it only remotely makes sense to replace the old one and ordered them. Now what?
You all need to make way more posts. Preferably with pictures. Lots of them. And video. Keep me entertained![]()
December 5th. Birthday present to myselfWhen did you order?
So the orders will be delayed again?December 5th. Birthday present to myself![]()
