SZZS CEF69 Build with New Bafang M510 3.0 version
Hi! Can you tell me what size headset the CEF69-ZS is? As far as I understand, it's 52ZS/52ZS?
Geometría
We will have it in Spain Seville for those who want to try it will carry the new m510rs
IMG_0644.jpeg IMG_0643.jpeg IMG_0642.jpeg IMG_0641.jpeg IMG_0640.jpeg IMG_0639.jpeg IMG_0638.jpeg
Now I'm going to build this frame with a 150mm Fox fork. My terrain is XC and marathon.
160-170
Hi Charly, I'm new member in the forum and I can't send you a PM yet. Can you contact me to discuss purchasing a CEF69 frame? Thanks a lot.
Hi guys does anyone know the spacing for the bottom shock mount? I'm going too run a rockshox deluxe and would like to know which bushing kit to order
Here are my 152mm pedals installed. I really enjoy the extra width and shortened length. They are steel.
View attachment 173758View attachment 173759View attachment 173760View attachment 173761
Nice i was going to order the miranda cranks but they are almost 3x the cost and aluminum, i think ill order those aswell thanks :)
too many Q factor ( 😭 kneees), i suppose that this crank arms are dedicated to fat bike ?
Feels much better than straight ones, plus you gain even more clearance bringing the arm out even more instead of being straight down. Very Happy with these, plus a weight savings.
Hello guys,
I've just received my frame, motor kit and battery. The frame arrived with the motor installed. I'm wondering how to install the battery. I guess I should remove the motor first. If someone could share any related pictures or assembly manual I would highly appreciate.
Kind,
Velin
P.S. I've installed the battery, first removed the motor.
Hello guys,
Kind,
Velin
Ask Jean if U buy from her, she can provide video installation.
To install the battery, you have to remove the motor. Insert the battery and screw it to the frame with the four screws. The battery comes with two connectors: one goes to the bike's charging port and the other to the motor. Once installed, reattach the motor.
I have some videos but I don't know how to upload them here. You can find me on Facebook or Messenger as Charly Boje. I'm a sales representative for the SZZS Bike brand in Spain.
You need to get one it doesn't come with a frame?
I'm not sure I haven't received my frame yet but I wanted to be prepared for the build when it arrives and for the sake of a few quid I just ordered it for piece of mind.
  • Like
Reactions: ssl
Hola a todos los amantes de las construcciones caseras de Bafang. Aquí les presento mi nueva construcción casera con cuadro SZZS CEF69 y la nueva versión Bafang M510 3.0. Batería de 48 V y 700 Wh. Jean me comentó que la nueva versión es de 48 V y 835 Wh con carcasa de carbono. Tengo el extensor de batería externo de 280 Wh, pero aún no lo he instalado en la bicicleta.
Con esta construcción pesa aproximadamente 21,5 kg.
Buenas tardes. Estoy interesado en este cuadro CEF 69 con su batería. Mi nombre es Pepe con tfno 607195521. [email protected] Si alguien me puede pasar datos de comerciales precios etc. etc. Lo agradecería. Buenas tardes para todos
Buenas tardes. Te interesará este panel con tu batería. Consulta el precio, contacto comercial, etc. Llámame al 607195521 y mi correo electrónico [email protected]. Sin otro particular un saludo para todos.
    668K
