Tapping the Turbo Levo battery for USB?
jxj
Deep in the Beauty of Nevada
I have seen some discussion and video about tapping the battery for front headlights and have read that there is a jack for a tail light both to be powered by the main bike battery. The headlights I'm aware of are Lupine and Supernova. I haven't seen anyone put a tail light on the Lurbo Levo, anyone?
In this document it appears that Brose offers and on on the Bulls E-Stream EVO AM 4 they have a usb charging port on the handlebar control assembly and/or display.
https://www.douze-cycles.com/docs/BROSE-ebike-Manual-English.pdf
My question is has anyone found a way to get usb power out of the Specialized Turbo Levo to keep a phone charged on the bars? I'm running Blevo and would like to keep it bright and my phone runs down just before the main battery.
Yes like that but on a turbo levo. I've seen the light hookup but no usb output via the light cable. Looks like there isn't a commercial solution yet. Spec if you read this it would be handy to be able to get a 1A or more usb charging capability on the Levo IMHO.
I run my phone on the bars and never had it go dead on a ride. Do you have a bunch of other apps running in the background? I have a portable charger that can recharge my phone in 30 minutes that I take with me for long rides but I have never needed it
I would quite like a USB charge port. By the time I have driven to the trails playing music, ridden for an hour or two using Strava and occasional maps/messaging/email, and driven home, I'm usually below 30% battery. My next move might be to upgrade to a phone with a headphone socket so I can play music and charge at the same time.
have bought a power lead that plugs into the Brose battery for the front lights (supernova) - plan to use the plug and lead to provide power to a gps tracker, and a micro-usb plug near the handlebars. Will post a thread here when Ive done it, but should be relatively easy to do.
Is that for a 2019?
yes. .Front light connector the same as 2018, rear different.
Nice. I didn’t know. Looking forward to what you come up with. I just spent the day dealing with adding 12v wiring to my vehicle for extra power. I am glad that is over with. :)
I know the light output on the 2018 Levo is 6
volts and a standard USB is 5 volts. Something to think about
hi - have now got all the parts, but am probably just going to tap it for powering my hidden gps tracker, and for a power connector for my front lights. Am debating putting it in though, but it might joust make the front of the bike too cluttered, and I'm not sure I need it. When I get round to doing the other bits I'll post up a thread on them tho.
I was just thinking of trying something similar. I believe I read that on my 2020 Levo the front wire light was 12v and the rear was 5v. If that is true, 5v seems like plug and play, but then again there are plenty of 12v usb connectors available as well so both should be easy. I was out for 4 hours Sunday and my phone died right at the end.
Interesting. I’d like to hard wire the Invoxia gps I’ve added to the turbo levo sl 2020 I have. In the simplest way I guess the rear light is 6v, standard usb is 5v that may work direct if the rear light port on the bride motor. Or the front light is 12v and you can get a 12v to 5v usb from Amazon pretty cheaply and the wire to the 12v front light. Has anyone tried this? Or has experience before I play around and fry my expensive bike motor?
thanks in advance.
These might help you a bit further, but they're not SL's ..
