I don't think trying to measure rotors with calipers will work, you need to use a micrometer.I measured them with a Vernier.
Agree. A slight misalignment on the rotor or a ridge on the rotor surface will give the wrong reading.I don't think trying to measure rotors with calipers will work, you need to use a micrometer.
The way I look at it is the lip that gets created between the outer edge of the disc, and the wear surface, I think you refer to it already as the 'ridge'. You cannot really measure wear with a pair of calipers. However, the OP simply seems to want to point out that the original rotor was thinner than the replacement so it's possible for that purpose the calipers served the purpose well enough to illustrate their point.Agree. A slight misalignment on the rotor or a ridge on the rotor surface will give the wrong reading.
Will do! I never would have guessed that the rotors could be the culprit. But AI tells me, "metal-on-metal contact caused by high metal content brake pads grinding on cheap rotors can amplify squealing sounds." So I will try to find some better quality rotors rather than change my sintered pads.Change the rotors out to something else.
I had multiple mates with same problem and read plenty of posts saying it's the rotors. I'd change them first before changing anything else. Good luck hopefully it fixes itWill do! I never would have guessed that the rotors could be the culprit. But AI tells me, "metal-on-metal contact caused by high metal content brake pads grinding on cheap rotors can amplify squealing sounds." So I will try to find some better quality rotors rather than change my sintered pads.
I'm wondering if it's worth it to change to a floating rotor?I had multiple mates with same problem and read plenty of posts saying it's the rotors. I'd change them first before changing anything else. Good luck hopefully it fixes it
Like these?I'm wondering if it's worth it to change to a floating rotor?
lol. I use my levers, when you install new pads if your levers are already half way to the bars your rotors are too thin.I use the fingernail-drag test
That is a two part problem. One the storm rotors are junk, hated them. Second the pad material is why they have a special bed in process. They are harder pad material than most other types. Mine bed in fine but took almost a 90 miles and 13,000' of dropping, and I changed out rotors after 60 miles.MT7's are super finicky
Put Shimano levers on and Galfer purple pads .I have a new Amflow Carbon PL Pro. It would be a great bike if it weren't for...
I've done my first 10 tours (13,000 metres of elevation gain and 320 km). I've taken the bike to the repair shop three times, watched three videos about the well-known Magura problem and spent at least five hours in my workshop myself.
-Cleaned and finely sanded the brake discs.
-Sanded and replaced the brake pads.
-Aligned the brake caliper countless times.
-Reduced the amount of brake fluid.
-Pushed the brake pistons all the way in countless times.
Nothing helped. The brakes continue to squeak and roar merrily along. It's almost unbearable!
If it's a defective part, that can't be normal on a € 10k bike, can it?
Dobrý den, omlouvám se, ale z vašeho komentáře mám dojem, že máte na mysli brzdění vozu Formule 1, nikoli běžného jízdního kola. Brzdy musí fungovat i v blátě, vodě a dalších nepříznivých podmínkách. Nechápu, proč z toho děláte takovou vědu.Myslím, že je vhodné oddělit příznaky problémů s brzdami, abychom se mohli zaměřit na řešení.
Problémy se seřízením brzdových destiček/třmenů způsobí tření brzd a v případě extrémnějších vibrací, které můžete cítit i přes brzdnou páku... a samozřejmě také špatnou brzdnou odezvu. Nic z toho nezpůsobí skřípání při brzdění.
Hlučné problémy s destičkami na rotoru jsou způsobeny špatnou přilnavostí mezi destičkami a rotorem. Klasickými příčinami jsou...
1. Znečištění kotouče. To může být způsobeno různými aerosolovými čističi/leštidly, i když jsou nastříkány v dostatečné vzdálenosti od kola, ale v uzavřeném prostoru. Patří sem také některé obecné neaerosolové čističe a samozřejmě oleje. Pokud na kole používáte jakékoli čisticí/mazací prostředky, je nejlepší nejprve zakrýt kotouče. I dotyk brzdového povrchu rukama může kotouč kontaminovat. Mezi další příčiny patří znečištění vozovky/výfuku, pokud je kolo přepravováno na korbě auta/dodávky, ale pravděpodobně zdaleka největší příčinou je špatný postup zaběhnutí brzdových destiček. Spékané destičky se nejobtížněji zaběhávají.
2. Použití nesourodých destiček a rotorů. Některé rotory jsou navrženy pouze pro pryskyřičné destičky.
Jak tedy zaběhnout destičky? Proces zahrnuje přenos vrstvy živice z destičky na rotor, zatímco vypouštění vzduchu zahřívá rotor. Nejlepší způsob, jak toho dosáhnout, je strávit 10/15 minut na klidném úseku silnice jízdou střední rychlostí a poté silně sešlápnout jednu z brzd, dokud se téměř nezastavíte, a poté brzdu uvolnit. Opakujte několikrát. Po každém sešlápnutí byste měli cítit, že se brzdný účinek zlepšil. Opakujte s druhou brzdou. Klasickým znakem, že jste to neudělali správně, je černý usazenina na rotoru... způsobený teplem!
Jak se zbavit nečistot? Použijte dílenskou utěrku namočenou v roztoku IPA a v případě potřeby otřete obě strany rotoru čistším hadříkem, dokud po otření nezůstanou žádné stopy. (Z mých zkušeností je používání údajné brzdové kapaliny na tento účel horší než k ničemu!). Nevidím důvod používat na rotor jakýkoli abrazivní materiál, pokud není poškrábaný. Nikdy jsem rotor nebrousil!
Podložky lze nejprve čistit IPA a bavlněným hadříkem, poté mokrým a suchým brusným papírem o zrnitosti cca 1200 a poté znovu IPA. Nepoužívejte brusný papír!!
Teď budete muset znovu vložit podložky, i když podruhé to bude rychlejší.
Too skinny, i would burn them up in 2 months.Hope rotors
I tried the Magura floaters there thicker but too thick with new pads had to put in old pads just so I could get the wheel onToo skinny, i would burn them up in 2 months.
You were doing something wrong, because im using 2.3mm wide rotors and they fit on with ease. The Magura are only 2mm and made for those calipers. Hopefully you took bleed screw out when compressing caliper pistons. Or used bleed port.but too thick
I was wondering about this as well.compressing caliper pistons.
100% mine took a 100 miles to bed in. I swapped out rotors and the Magura MT7s are the best brakes I have ever run and I descend over 560,000' this year. No contest against my Shimanos, the mt7s are far better. The storm rotors suck. I suspect the Magura brakes just take more miles to bed in and improve?
