100% because it is a trail bike, not an enduro or DH bikeAmflow is not on par with the other Enduro focused bikes
Well it’s not an Enduro focused bike so I don’t know why they’d be comparing it to those.the reviewers mention that the ride quality of the Amflow is not on par with the other Enduro focused bikes
unfortunately non standard: Buy Amflow PL Headset - AMFLOW StoreDoes anybody know which type is the amflow headset?
That's not how the free shift works. The derailleur must actually shift and draw power from the motor, to cause the motor to run. He has damaged something when he fell for the motor to continue running.Yesterday, while riding with a friend on his Amflow (trying to keep up with him—that thing flies!), he fell on a tight turn. When we tried to lift the bike, the motor kept spinning along with the wheel. He turned it off and on to try to reset it, but the wheel kept running and the bike kept trying to shift.
We figured out what happened: when he fell, he pressed the shifter unintentionally, and due to the Free Shift function, the bike kept trying to complete the shifting procedure.
I found that a bit dangerous — it could hurt your fingers or hand in the process. It should only shift when the bike is moving upright, not when it’s lying on the ground and being lifted.
exactly. That is why I ordered Velduro so I can enjoy a 170/170mm setup ... somehow an e-dh bikeBecause it´s a trail bike?!
'At least" maybe you should ask a credible question.At least
will never exist in reality, you are asking them to answer an imaginative question.Would a permanently engaged freehub while coasting
That is also imagination based since software may not solve the issueaddress this with a software update
BULLSHIT. They rattle.'At least" maybe you should ask a credible question.
They have addressed the rattle already, and later models do not have the same issue as earlier releases.
Yes it is. The brake surface and socket of centerlock brake disc is planar (at least the left looking side) so a sandwiched sensor ring comes to rest exactly the same distance to the sensor as it would be if it is mounted on a 6-bolt disc.Hey team,
Hope you are wellI’m getting a DJI bike soon (Rogue) and the wheel set I was planning on using has Centerlock rotors. Has anyone fitted the speed sensor disc to a centerlock rotor? I assumed it was 6 bolt only, but watching a Megamo video I see this;
Might just be sandwiched in?
If no visible damage, you are probably fine. You would have heard it break if it did, makes a hell of a noisewhat the likelihood of the headtube area been damaged from the crash?
Right there. But they offer a crash replacement that is cheaper than full priceI've gathered
The factory specs are loose enough on slow impacts things give a little. You are probably fine. And did the right thing, Not riding it further and having it looked at
one guy here rode with it very loose, and he was over the recommended weight limit, for a long time. still riding it. did cause some paint cracks.Can a loose headset cause damage while being ridden even if it was only for a short while?
dudes a foolthe carbon is weak
Can I have a pictures of entire battery, Thks10s4p LG
La batteria è difettosa
È stata inviata una sostituzione in garanzia
Tks a lot, could I see the PCB? Thks
No problem of course if the price is suitably loaded to take account of Norwegian warranty regulations.Noticed today a major Norwegian bikeshop is starting to sell Amflow and spare parts which means under norvegian warranty regulations and Consumer Purchase Act which gives 5 years warranty.
Interesting![]()
I compared with US and UK and the price is around the same since NOK is very weak at the moment NOK 75.00 and 115.000 and the shop is not a tiny backyard shop.if the price is suitably
