yes but what you are describing fails to take account of how the software engineers take 2 main sensor inputs ( cadence and rider torque...and to an extent bike speed/ on some bikes even elevation) to create an algorithm in order to convert the raw output torque response of the motor to a more natural and progressive nature. It is that algorithm that largely dictates the "character" of the motor, maintains traction and control. There is clearly on most motors an assumption of the average torque input of a reasonably fit rider......probably a long way below that of a pro rider or even a fitness fanatic. I ride both Bosch Gen 4 motors and Spesh Gen 3 ( previously gen2), and in stock tune it is easy to feel the difference. Spesh has in my experience always delivered more power at lower cadence than the Bosch motors. What i was suggesting was that from the feedback I have seen Spesh have over egged power delivery within that algorithm on the new bike and maybe needs more modes to get a more even spread.
If you have essentially 3 modes, ECO, trail and Turbo with the ability to set each for different motor support to meet different riding requirements on a ride, you would expect to set ECO at about 35% as a battery saving mode, trail at 50 or 60 as a "do most things" mode and turbo at 100% for extreme climbs. Otherwise what is the point of the extra power?? If in fact trail is plenty powerful enough at only 20%, and to go beyond that uses too much battery, it just suggests that the system overall is more powerful that most people need. More power which ever way you cut it equals more battery use, more heat and more wear and tear.
