AlumiPro
Correct.This is why on the RH2 size with 450mm reach and 440mm CS makes sense as the shorter CS helps to better pick up the heavier front end. On the R180, the CS was 445mm on size medium.
I ordered an RH4 (505mm reach) 27.5 rear w/ 440mm rear center drop out. This size frame would have been shipped with a 450mm rear center drop out, And if I don’t like how it rides I can always order a different drop out.
My Anakin V2 MTB (obviously has no forward battery but has a centered gearbox) is a size XL with 500mm reach and 428mm rear center with its current configuration.
I like a roomy cockpit but ride very tight single track “deer trails”, so prefer a “smaller” wheel base for tight switchbacks.
