I am wondering if removing the battery cradle, the 4 screws, will give me assess to AXS Hotshoe connector?@GZA or anyone who attempted to install cable actuated derailleur
Can you advise, if there is a way to disconnect "AXS Hotshoe" cable from AXS Y-splitter cable coming from display location, which is located somewhere above the motor, according to diagrams above.
I need to do this to disconnect the AXS battery cable, remove the battery and cable and use the passage in chainstay for RD cable.
View attachment 183757View attachment 183756
I’m not using either the splitter cable or the hot shoe if they’re of any use to someone
STEPS: just done itIf I recall correctly the hotshoe had a push connector that I had to drop the motor to disconnect from the splitter cable
Thank you very much for posting this - extremely helpful. Do you have access to the Levo R workbook as well? From working on mine there are a number of differences - thanks again!Converted to images for easy reading if you don't want to open the PDF.
PDF is also attached at the bottom.
Hi, sorry, no, not so far - haven't looked to be honestThank you very much for posting this - extremely helpful. Do you have access to the Levo R workbook as well? From working on mine there are a number of differences - thanks again!
