Levo Gen 4 Levo Gen 4 - Discussion Thread for 8th April launch
Status
Not open for further replies.
I believe those numbers are in Euros
In US:
S-Works- $13.5
Pro -$11.5
No looks like US$
I think you mentioned the possible elephant in the room. With this extra power I can see an increased rate of chain & cassette usage. That will be the next item to deal with in an upcoming facelift model or the Gen 5 Levo.
Increased usage will probably be the catalyst for the MGU to come on stream next next gen.
Yep, T-type chains wear fairly fast as is on my Levo3 due to the extra demands
Post #295 response.
Industry standard for 52v systems is 14 cells in series, 48v = 13 cells, and the gen 3 levo which I have is 36v and has 10 cells in series per group.
Has nothing to do with motor load.
Different discharge rates on cells and capacity (ahr rating ) is how they are classified.
Higher voltage equals lower amperage for the same wattage output.
Highest rating for 18650 cells is 3.5ahr.
Highest rating for 21700 cells with the “new” Samsung 58E cell is 5.5ahr rating, previous max for their 50Ecell was 5ahr. They’re probably going to continuously rate it at 5.8 ahr but testing doesn’t support this but marketing is what it is. Just sayin.
As far as the 840w battery not being possible I gotta disagree.
840 ÷ by 48v = 17.5
Using 1850 cells rated at 3.5ahr would need 13s5p which is 75 cells at 48gr = 3600 grams.
Using 21700 cells rated at 5.8 ahr rating would use 13s3p which are 39 cells at 68.7gr = 2679.3grams.
Battery manufacturers a lot of times round “up” when rating their products.
I have an aftermarket extender battery ( trailwatts ) on my Levo and it’s rated at 252w meaning it’s a 10s2p configuration but I can only use it in parallel with the main battery and it measures in at 3”x7.5” and fits where the water bottle cage is and that’s with the shock strut. So eliminating the strut should allow a 280w battery to fit easily.
Not sure about your guys standard 4a chargers which is common but mine gets hotter than sh-t when charging. Supposedly that’s normal.
Looking at the pics of the “new” charger with the fast charge capability it doesn’t look
Iike there is a cooling fan or anything to help disapate the additional heat from the increased charging current. So that will be interesting to see how they handle that issue
Hey love the conversation here, yes your points on the standard for 48V systems stand on solid grounds.
The first reason why I speculated on 14S3P and 14S2P was first because the 52V and 48V ebike system aren't to far apart from an electrical point of view. Adding a link to a page that talks about the interchangeability of the 48 and 52V systems, what the advantages of 52V batteries on 48V motors are and what the advantages of 48V batteries vs 52 are.
The second reason was because of the Levo spec number of 840Wh and the currently most popular high capacity cell from LG the M58T with a capacity of 5,57Ah.
42cells(14S3P) x 5,57Ah x 3,6V = 842Wh
But hey we all can be wrong, there are different points of viewing things.
If we take the fact it has the new Brose motor and that they kept the original Brose battery specs then the battery in fact are both a 13S3P configuration but using different capacity cells.
The original Brose batteries are 814Wh and 632Wh which would imply to:
13S3P - 39cells x 3,6V x 5,8Ah = 814Wh
13S3P - 39cells x 3,6V x 4,5Ah = 632Wh
If Spesh used this configuration then that means they for marketing names rounded(like u implied) up for the big battery and down for smaller battery.
The 840-Wh battery has 39 cells, each containing 13s3 p (6.0 A x 3.6 V = approx. 840 Wh). The rated voltage is 46.8 V and is rounded to 48 V for marketing purposes.
However, I don't think the full 840 Wh can be used because the battery switches off at a cell voltage of 3 V instead of 2.5 V. I think about 780 Wh is usable.
Do you maybe know which brand cells they use for each battery pack?
I think that is more important than the pack capacity numbers, the quality of the cells and a good BMS is key for a good performing battery pack.
In my opinion, the key to the battery design is:
- "SWAT storage, side entry battery" on the frame details spec and
-"SWAT internal downtube storage".
The battery will be split into two parts that together will give 840wh of which 210wh/280wh will be removable laterally leaving space for the SWAT.
Long rides with a lot of battery and backpack.
Short rides with little battery (630wh - 560wh and SWAT.
It also possibly supports the range extender in the bottle to exceed 1000wh. In fact it has two versions of range extender
A Levo aluminum base for 7,000 euros? So I'm not going to wait to upgrade to a CUBE.
Too bad to leave Specialized!
Man, guys here in USA that new bike is going to cost a lot because of the new import taxes. Glad I bought a gen3 comp on sale a couple of weeks ago. Man it just bad timing right now.
suddenly this is all getting interesting. Let's see what the US pricing becomes, and we'll all decide then. I am more keen on the direction of this bike, more, and more. Now whether this is the next coming of J, then we'll have to see. For most, switching to this new bike might be a wait thing, for someone ready to purchase, what is another 2-3k US dollar premium to pay for the bike you really want, vs. Amflow which really just has the power.?!?
I was wondering the same. As for the tariffs, let's see how many bikes were already paid and are in the USA already.
When will they announce the new version? All I seen is many pictures on this site, nothing on website.
Post #338 question.
What 21700 cell has a 6ahr rating?
5ahr is max here in the states and the 58E is only 5.5ahr.
As far as using 52v battery’s for 48v systems that used to be the way to go but most BMS manufacturers changed that back in the beginning of 2024.
Bafang for example, cant use a 52v pack with a newer 48v controller.
You can re-flash the software to go from 48-52v but it’s a process.
Better to just stay in your lane with the correct voltage.
Saw an sworks in person today. Unreal. Paint is colorshift burnt orange/dark red/dark blue/black metallic.
You can indeed switch between class 1 and 3 via the remote. Battery size is smaller than I expected.
Swat just behind the headtube and about the size of a small seatbag.
2.3” tires. Definitely room for 2.6”. Definitely no room for 29”
Many hated the new black app after the old red was taken down so is it going to come a completely new app for the G4 or will the black work?
My dealer just confirmed my pre-ordered Sworks bike has shipped. Should see it on Monday. Great news!
Please if you could DM me with pics I’ve ordered but there’s a delay on the shipment transport issues
If you could send of the battery side especially apologies to ask but in a crappy situation
from design it looks identical (at leat for me) like an SL2 just a more fat downtube...
It was discussed in the original (now closed) thread.
But yes, it's pretty similar, Gen4 over an SL2
We did a mockup based on an SL adding in what we knew and had this before there were any leaked images, we got a lot right, mainly due to the SL similarities to start with :
First real image of the all blacked out version? 😧
It was only the mockup, quite a few things were wrong compared to the actual Gen4. The image design was discussed here - mainly the area round the headtube was completely wrong, but it was only supposed to be a rough guess.
Status
    Join 43,135
