Levo Gen 4 Levo Gen 4 Rumours and some facts...
Status
Not open for further replies.
Mount a Fox Transfer Neo and you have the Levo G4 S-works ;)
Better ?
The downtube is big, but not that big, and motor is more compact. I promise that the SWorks is going to more than a groupset upgrade and a Fox dropper. On top of that the price is the same or less than the outgoing model. For all of those people that complain about what stuff costs, try to keep in mind the fact that although inflation has skyrocketed in a lot of places, the price of a levo has gone down over the last 3 years. I’m not saying that the prices aren’t insane, but I’m saying that in all actuality they are way down.
Retail in Europe
S works Frameset 7500€
S Works complete 14500€
Pro 12000€
I don't know if this article has already been posted, nor if the source is reliable, but it seems to contain some information that could be plausible...
The key information from this article “Rumour: 2026 Specialized Turbo Levo. A Beefier SL Version”:
Motor System
  • Specialized will no longer use the Brose motor and has instead developed its own proprietary motor.
  • The new motor design is inspired by the Levo SL, with significantly reduced drag when the motor is off, offering a more natural pedaling experience.
  • Two motor options are expected:
    • A powerful S-Works-only motor delivering 120Nm of torque, designed for aggressive riding and steep climbs.
    • A standard motor option with slightly less torque (exact figures not yet released), but still capable for most trail scenarios.
Battery System
  • The 2026 Turbo Levo will feature three different battery options.
  • This gives riders the flexibility to choose based on the type of ride—larger batteries for longer range or smaller ones for a lighter setup.
  • The modular battery setup allows swapping batteries depending on ride length or terrain.
Frame and Design
  • The new frame design is influenced by the Levo SL and the latest Stumpjumper.
  • It is more streamlined, lighter, and aesthetically refined compared to previous versions.
  • The redesign focuses on agility and responsiveness, enhancing the riding experience especially on technical terrain.
Suspension: Genie Shock
  • The 2026 model introduces the Genie shock, an advanced suspension system.
  • It adapts to terrain and rider input to deliver a smoother, more controlled ride.
  • Described as having a "coil-like" feel.
  • Adjustable geometry allows customization for different riding styles and trail conditions.
Weight
  • The 2026 Turbo Levo is expected to be lighter than the predecessor
  • The combination of a lighter frame, efficient motor, and battery setup contributes to improved handling and performance.
  • Despite the weight reduction, the bike retains the premium feel associated with the Specialized brand.
They don‘t have any clue. You will see at release of Levo 4 😁
I gotta keep my trap shut about it but I’ve now seen pics and got to hear about the specs. The S Works is going to absolutely change the industry. Many of the recent predictions about the power and battery sizes are close enough, if not 100% correct, but you guys are not thinking outside the box enough. Specialized is really coming out swinging this time….and that moc up pic is pretty accurate. The bike looks good.
If it still has a rear mech, then it is not really “outside of the box”
I've had my 2020 levo expert since the end of 2019 and I'm about ready to get a new bike. I just need to decide what to buy.
I paid £5800 with discount for my bike (then upgraded the saddle, handlebars, wheels, suspension, brakes and gears). Adjusted for inflation that takes it to around £6400 equivalent in 2025 for the base bike.
I might be able to afford the frameset, but I hope it looks better than zims mockup ;)
I'm sick of having a bike that looks pregnant and would like something a bit sleeker.
I'm sure if someone takes the time to photoshop @Myke's turd coloured bowling ball over my shoddy mockup, it will look amazing ??????
Is anybody who has seen the bikes able to say if the s-works frame still has holes/guides for cable derailleurs?
(Edit) Also what would be the closest size to a gen2 medium? S3?
Any Idea at which point the frameset (only) would be made available? As I recall. the G3 frameset option wasn't offered until quite late in the game.
Will the new Gen 4 Levo be able to use a battery range extender? If so, can we just use the SL battery range extender? I still have the SL battery range extender from when I had my Kenevo SL.
Yes the Gen 4 will accept a range extender, however the SL extender battery likely not compatible, The Gen 4 system is 48v and the Sl is 36v.
How about a frictionless motor that can be used like a normal bike with the battery removed for uplift days?
After the initial release and fast chargers they will compliment the SWorks bike ( the extender) with the initial release the SWorks gets a 80% charge in 40 mins super fast charger instead
Are you saying that the S Works has something, not counting a slight torque/power bump, that sets it apart from the rest of the model range?
gearbox?
So far I didn't read anything that sounded revolutionary. If only the S-Works would have a gearbox it would be kinda weird.
Status
    Join 43,142
