Evilkenevil
Hi all, I have the SL 2, it has the Float X installed. I'm considering upgrading to an X2, not the one that explodes. Just looking for others opinions before splashing the cash. Would it be worth it/noticeable?
What do you want to achieve by swapping the float X?Hi all, I have the SL 2, it has the Float X installed. I'm considering upgrading to an X2, not the one that explodes. Just looking for others opinions before splashing the cash. Would it be worth it/noticeable?
Hey. I just want it to feel a bit more lively. Just like you said, more pop would be nice.What do you want to achieve by swapping the float X?
I find the tune and functioning really great on the Kenevo, easy to set up, poppy, can even increase the travel just by removing spacers![]()
In that case the X2 might be a step in the wrong direction…Hey. I just want it to feel a bit more lively. Just like you said, more pop would be nice.
Hi!Hi all, I have the SL 2, it has the Float X installed. I'm considering upgrading to an X2, not the one that explodes. Just looking for others opinions before splashing the cash. Would it be worth it/noticeable?
I really like this guy….. he has a couple videos on the x2Hi!
I just swapped the X2, you know what it implies... (sent it to FOX customer service for updating ). Good shock (only for a short time...) but using a lot of travel, lacks support for my taste. Never felt it lacking "pop".
Started riding with a CANE CREEK TIGON, I love their KITSUMA (on my COTIC ROCKET MAX, reliable, damper adjustments effect very noticeable).
Still tweaking the TIGON but for sure the front/rear balance fits me better. Interesting shock mixing coil and air springs for the last part of the travel.
Hope, that helps if understandable!
Yeah! Went through some of his stuff while gathering informations. I won't go back to the X2, it's 2024 up to date and for sale, never ridden...I really like this guy….. he has a couple videos on the x2
From my experience, I would say that poppiness deals with high speed rebound (if available). Not related to spring type.Hey. I just want it to feel a bit more lively. Just like you said, more pop would be nice.
on my levo with cascade component, my X2 under need of a fix works way better than the float X. But bored to hell, i also switched back to float X.I've gone back to the Float X after 2 years on a coil. "Why?" I hear you ask. Just because, no real reason for it.
I saw this, however the negative spacer is only in some of the shorter stroke versions and has been there for years, the longer stroke ones don’t have it, I quite like his channel but he tests most of the products on what looks like a glorified trail path.Yeah! Went through some of his stuff while gathering informations. I won't go back to the X2, it's 2024 up to date and for sale, never ridden...
Saw this, pretty sure he going to have issues with his chainring.
Interested to read your thoughts on that.Saw this, pretty sure he going to have issues with his chainring.
Concerned about the “pin” and the tolerances used. Also was the bolt hardened as well as the sleeve? Loose fitting pin in the driveline sounds like a creak machine with increased free play….Interested to read your thoughts on that.
I do, but with a 27.5" rear wheel...Does anyone run their KSL in steep and high? Just thinking 64.7 head angle isn't exactly steep, it shortens up the wheelbase and might make it a bit better in tighter corners? That's more of a question than a statement as I haven't tried it. Hoping someone else has to save me the effort![]()
I was but I moved to steep and low with a little bit more pressure in the shock, I like the longer chain stay better for climbing even with tight corners.Does anyone run their KSL in steep and high? Just thinking 64.7 head angle isn't exactly steep, it shortens up the wheelbase and might make it a bit better in tighter corners? That's more of a question than a statement as I haven't tried it. Hoping someone else has to save me the effort![]()
