New Fantic Fat Sport Integra - Info Updated Regularly
BMP
Iowa USA
I just purchased this bike from Upway at a great price. 1950 with a 100 off coupon code seemed to be a no brainer. I'm looking forward to getting miles in this winter on a more capable bike. The only things I have done so far are a Quad Lock phone mount and will go tubeless soon. One thing that I noticed immediately was how quiet the Brose T-Alu motor is. It is way quiter than my Bosch Gen 4 CX Perf. Also the Fantic app is actually pretty decent and the display is much better than the Purion that my Gen 2 Rail has. Overall I am super happy with the purchase. It will be getting some Renthal bars and an Apex stem soon.
Brad
12-21-24:
Tubeless set up is done. The shop used the stock rim strip and added rim tape and Stans Tubeless schrader valves. The wheels were already drilled oversized. The presta valve tubes that came stock worked OK, but the hole in the rim was way too larger for a presta tubeless stem. They hold pressure rock steady with the Orange Seal sealant. 👍🏽
1-6-25:
Added RaceFace large Chester pedals. They fit my snow boots perfect with tons of grip.
1-13-25:
Added a Renthal Fatbar 35 in a 30mm height and Apex 50mm stem.
1-18-25:
Swapped out the SX shifter and derailleur for XX1.
2-19-25:
Added an internal OneUp 30.9 X 420mm - 150mm dropper post and a Wolf Tooth dropper lever. Pics on page 2.
6-24-25:
Added a Aeroe Spider FAT rack and two 12L dry bags. It added 4 pounds of weight total with empty bags. Pics on page 2.
7-1-25:
Added a Speedbox 3.0. Install was way easier than on a Bosch Gen4 with tight fitting skid plate. I got it up to 28 mph with a 105 rpm cadence on a flat road. Looks like it should top out around 33-34 mph spinning hard.
Just got one of the last ones they had, too good of a deal to pass up! Did you have to anything special to get the Fantic app to connect to the bike? I am not having any luck.
  • Like
Reactions: BMP
I see they are all gone now. Must have sold the last ones quickly.
You have to establish a connection on the handlebar display on the bike to the app.
Brad
Yeah, they had 3 left on Christmas morning and they were all gone by that afternoon. They reduced the price by $200 and they had sent me a post card with a discount code for $150, tried it and it worked also! Got it down to $1600/$1800 w/taxes and shipping. Unbelievable.
Thanks for the tip. I had not played around too much with the display settings. All connected now.
  • Like
Reactions: BMP
That is so awesome! What a crazy buy! The Fantic app is very useable and works well.
Brad
Been riding/feeling out the bike the last couple of days on my local bike path route (12 miles roundtrip). No real snow currently on the Denver Front Range and not wanting to travel up I-70. Am really impressed with the build quality as I had never heard of Fantic. Figured being Italian it would be good. I did find something that I was not overly concerned about but did add some extra protection to. Under the down tube there is a plastic cable router fastened to the frame. I had removed the battery and was admiring the cable routing clips underneath battery and reached up inside towards the headtube and was surprised at the 2 sharp screws used to secure the cable routing piece to the downtube. I decided to add some plastic protectors on top of those screws from rubbing on cables routed nearby. I am wanting to convert to tubeless but have not found any information about the rims if they are tubeless ready and have popped the tire off the rim yet.
*** just saw your edit/addition to your original post about going tubeless.
View attachment 152627 View attachment 152628
Nice catch on the screws!
My LBS did my tubeless set up. They seemed to think it was fine doing Stans tubeless schrader valves, 80mm Stans rim tape, and Orange Seal with the stock Jumbo Jim tires. Both of mine sealed up fine. They thought it was a little funny that the rims are already drilled out for the larger schrader valve size but used a presta valve tube stock.
Brad
I've been riding my Fantic Fat for the past two winter seasons in the Colorado front range - I ride on trails that have mostly snow. On the rare occasion that I ride in the dry season, I use the wheelset (80mm rim) that came with the bike While I got a good deal, all you guys got a GREAT deal. I thought about buying one as a spare for that low price but I already have a spare motor and extra batteries. The frame will fit the fabled Vee Snowshoe 2XL tire (120 TPI) - I'm running that tire, tubeless, on a 90mm rim. My first 2XL tire fit with no problems. The second tire required some edge knob trimming. ALSO - I had to move the chainring outwards over 0.5" so the chain wouldn't rub on the tire sidewall. It still rubbed when in the lowest gear so I adjusted my derailleur stop so it wouldn't go into that gear. The Brose motor is nearly bulletproof - but not water proof. There is a company that created and sells a seal for the motor that I bought and installed. The motor is very serviceable. My previous efat had this motor and I have several thousand snow miles on them. This T Alu motor has the same form factor as the S Alu motor. The S Alu has a little more torque. The only way to tell the difference is by the part number label on the case. To minimize moisture entering the frame and the motor area, I seal the gap around the battery with electrical tape. As far as range, worst case, I'll get 10 miles when breaking trail in deep (>6"), heavy snow. I'll get 30 miles when riding on more snow packed conditions. Happy trails, the bike and motor are awesome.
Great information! Thanks!
Brad
So awesome to hear some long range feedback. Looking forward to some e fatbiking. Where along the front range is your favorite?
Thanks a lot for the mileage experience.
  • Like
Reactions: BMP
JB01245 - This time of year I ride every weekend, usually both days and I always ride trails with the most snow. A fellow efat rider sometimes joins me. I don't want to publicize any trails online. Send me a PM with your contact information and I will show you first hand, the closest snowy trails to ride.
Mileage update - 10 miles in heavy snow >6" deep - the worst case, and a rare scenario in CO. When the snow is light and fluffy, I will get more than 20 miles in >6" deep snow - this is more typical for a fresh snowfall in CO. Your mileage may vary as rider input and power level are a key factors. I still ride non powered fat tire, mtb and road bikes.
  • Like
Reactions: BMP
Sounds like a plan, give me a couple weeks as I just ordered a new wheelset (cheap Sun Ringle Mulefut 80 rims with 4.8 Maxxis FBF and FBR tires). I am up in the Thornton area and have done most of my fatbiking at places like Aldefer/3 Sisters, Elk Meadow, North Table Mountain and Buffalo Creek. Have always struggled in fresh POW as only had 3" tires on my previous fat bike and still learning about using super low pressures.
Edit *** After rereading my post I thought the 3" tire size did not sound right. Went and checked and my tires on my other fat bike are 4" but still seem super small compared to 4.8"-5" tires.
  • Like
Reactions: BMP
JB01245 - I've been riding fat in the snow since 2012 when a bought a Specialized Fatboy. I can show you some tips for riding in snow. Most peoples difficulties in snow are usually due to too high tire pressure and not the best choice of tires. Soft and deep snow requires only a couple of PSI of air: As a visual, your tire sidewall will be half its normal height.
The tires for riding fat bikes in the snow are typically 4.8" wide and include Surly Bud and Lou combo, the 2XL which provides the most flotation although it fits on very few bikes. Dillinger 5's and Johnny 5's are also good snow tires.
My "Snow Beast" upgrades - 90mm rims, Bud 4.8" in front, Vee 2XL 5.05" in rear, suspension dropper seatpost, Ergon SM e-mtn saddle, XT brakes, Ergon bar ends, rear rack and panniers, custom cradle mount for extra battery, Manitou Mastodon fork (will fit 2XL tire). On the rare occasions that I ride the bike in the summer, I put the original wheelset on with the 80mm rims and 4" tires.
I included a picture of my front chain ring setup in case anyone is considering adding a 2XL tire and needs to move their chainline. The other picture is from last year on Cottonwood Pass. The road is closed and it is groomed for snow sport travel. On the day of the picture I rode a 52 mile loop (I had my spare battery) that included the pass and other connecting snowmobile trails.
So most any 4.8 tire will work with the Bluto fork? The rear has tons of clearance. Love the set ups!
Brad
The Bluto will fit 4.8" tires on rims up to 100mm wide. May fit wider rims too. My other fat bike has a 4.8" Dillinger 5 on a 100mm wide carbon rim with the Bluto. The Bluto will NOT fit 2XL tires - that's why I bought the Manitou Mastodon which the tire will fit. See images below. The main reason the 2XL won't fit a Bluto is because of the tire height/circumference.
Go to MTBR.com for a wealth of information on all mtb's including fat bikes.
The following tire comparison is from mikesee on MTBR thread:
.The main reason the 2XL won't fit a Bluto is because of the tire height/circumference.
Those 2XL’s are huge!
Thanks again for the information!
Brad
Got the new E Fatty up Geneva Basin area over the weekend. Too much fun! A whole new meaning to "cutting trail". Got the new rims and tires yesterday afternoon and installed and am really digging the look with 4.8's!! Also threw on some riser bars that felt real comfortable on the ride.
Sweet place! Love the snow, looks premium!! Those bars look awesome! 40mm rise or higher?? I’ve got a 30mm Renthal bar and Apex stem in the mailbox RN for mine. Makes me want to try a taller bar next time. 🤘🏽
Brad
Thanks BMP, Spank Race 800 bars with 50mm rise, kept the stock stem for now.
What type of riding do you have in your part of Iowa? I have seen some clubs that have some decent looking trails that they maintain. Do you have to travel far for descent riding?
We have some nice trails along the foothills that have quite a bit of foot traffic so the trails get packed down pretty quick and are rideable soon after a storm.
  • Like
Reactions: BMP
There is a park within 8 miles of my house, North Overlook by Lake Red Rock. It’s pretty small but great riding with a mix of everything. We also ride in Des Moines about 45 miles away it has Denmans, Center Trails, Copper Creek, Sycamore and Banner down near Indianola. Our go to is Bentonville. We go multiple times a year. Probably should just move down there when my wife and I retire. 🤘🏽
Brad
Hey E&NonEinCO, being a new member to this site, I can't send a conversation request to you until I have 10 posts (almost there). Can you try sending me a conversation and then we can chat or I can send you my email? Want to pick your brain on transporting the bike and dropper post options.
Jay
  • Like
Reactions: BMP
Jay
I am going to put a dropper on mine as well. I have three of the TranzX's. Seem to be good for me and work when cold out.
Post up options and opinions guys.
Brad
XX1 engaged. Feels like X01 to me.
*EDIT* I think the lever throw is shorter than my X01. I thumbed a few double upshifts on accident when I first rode in the timber. It is crisp and short.
BradView attachment 153396
Sweet! I am new to SRAM, have always run Shimano XT.
Was out trying out the 4.8’s on the neighbors route today
  • Like
Reactions: BMP
What tire/wheel/hub set up is that? I'll bet it performs great!
I'm thinking I might do an additional set up with 4.8" and get studded tires for my stock set. I've got Hope Pro 4's on my hardtail and see that Hope makes the Fatsno in a similar Pro 4 config. Might be. good option. I run a Bontrager 108 on my Rail but I've heard they are quite unreliable on Fat Bikes.
Brad
Brad
I got these as a winter set-up - 26 inch Fat Bike Wheelset Sun Ringle Mulefut 80 Novatec Thru Axle W/ Tires | eBay
  • Like
Reactions: BMP
  • Like
Reactions: BMP
    672K
