What did you do to your EBike this week?
Laggan Wolftrax today arrived 11 am no one there . Cafe lad turned up 10 minutes later. Near the top met the lad who designed and maintains the trail clearing a few trees that had fallen across trail. Did two runs then back to van still nobody there cafe shut ten minutes later. £4 parking fee for day was all they made , that's not much profit. Took one look at Ayres rock and thought that looks steeper than summer when i did it 0, and on my own was the only excuses I needed not to do it. 20 years old this trail . I had a Xmas meal at 4 pm to go to at Kingussie with my walking club . I definitely made the best choice cycling the hill walking was horrible they said .
20241215_115421.jpg 20241215_122942.jpg 20241215_115928.jpg 20241215_123905.jpg 20241215_131214.jpg 20241215_134552.jpg
lastnight replaced front wheelbearings for my mrs's Ksl, its a Nukeproof Horizon v2 wheel and has done well as one of the wheels I bought from wiggle ~18 months ago...
think this one has done ~2000miles @ Bpw and most of them on her bike o_O
suppose I'd better get some more bearings as stock for whenever...
Rich.
This year's must have.
I put a new E-Wild on the rear and all went well until re-fitting the rear wheel. Anyone know of an easy way to re-fit the rear wheel with a Shimano LG derailleur? For the life of me I couldn't get the chain back on the small sprocket whilst lining up the disk with the pads..ended up removing the derailleur to give some clearance. Note..this is a Shimano Linkglide mech which only pivots on the bottom jockey wheel instead of the more usual dual pivoting derailleurs...and of course being Shimano it has no wheel change mech lockout button like a SRAM...a right royal pain in the backside.
if this is applicable as I havn't done a shimano for a while....
I use a bit of string or cabletie to hold the jockey-assembly up to the chainstay - if you can get this to work from my terrible description 🤭
Rich.
I was thinking along those lines but I don't think it'll work with Link Glide. So if anyone else runs into this problem order some spare quick links (part no. Shimano SM-CN900 11 speed) and save yourself a load of time , swearing, and hassle.
..just split the chain and give it a good wash in diesel/degreaser whilst it's off. 2 for less than a fiver on eBay, bargain.
Not sure if this would make a difference , but take the chain off the front chainring giving you a bit more slack.
What??? Linkglide is normal drivetrain, wheel changes are same as any other Shimano systems, just remember to release the cage lever and pull the cage away when you instal the wheel. I have 10 and 11 speed Linkglides in family. Sram is more clever because you can lock the cage, I have also GX on my Bullit.
    670K
