• Warning!!
    UK Pedelec Law
    Worldwide Laws
Derestricting bosch smart system
In the Flow app, “settings”
I have been using the speedfun furious evo easy+ now since may with 0 issues.
Hi there, just returned a speedbox after constant errors and about to purchase a speed fun , just wondering if you still have a good sucess with it ? Any problems or issues or still working great ?
Regards.
Regards.
My buddy says it still works great! Just plug it in and ride!
I've been reading this post carefully because I'm very interested. I recently bought a Cube Stereo Hybrid 750 SLX e-bike and I'm really happy with it, but I want to remove the speed limit. I called the store where I bought it here in Spain and they told me that the delimiters for the Smart System don't work well and give a lot of errors. I have a Smart System but without a rim magnet. Instead, I have the sensor on the brake disc.
I've seen that you talk about some systems that I didn't know existed and that stores in Spain don't have in stock. Before buying it online, I would like you to tell me if they work, without errors, for my bike. I have engine version 12.13.0. And I wouldn't mind removing the Kiox 300 display or deleting the Flow app from my phone. For me, it's more important to remove the speed limit.
Thank you very much!
I forgot tell you that I heard lot of problems with speedbox 1.1
And my doubts are about Volspeed v2 or speedfun furious evo
I have the volspeed V2 and done 80 miles so far with no issues just don't use the flow app and turn blue tooth off phone so far so good
I've done 300 miles and smart lock on and no error. I think it may pick up it after a few 1000 miles if the cadence doesn't match the speed but the bosch system doesn't know what chain ring I've got on software hopefully not.
Or eventually the total milage won't add up but who knows 🤷
Still love it I'm picking up speed now
I've done 300 miles and smart lock on and no error. I'll think it may pick it after a few 1000 miles if the cadence doesn't match the speed but the bosch system doesn't know what chain ring I've got on software hopefully not.
Are you using Volspeed v2 as well?
Many thanks for the info
Nice, my idea is do the same, to prevent send info to servers or something with the app running hide
Hmm
I notice the speed stays below 16 mph if I'm going 20mph. But if I go down a hill without pedalling it shows the real mph.
The only reason how I'd see it being detected is the cadence and how hard u pedal but that must be a difficult calculation. And to take in bigger chain rings and bosch can't detect this it compensates for the more pedal strokes and higher speeds.
Maybe thats why its very difficult to detect under 21 mph because bosch compensates if u installed a bigger chain ring.
Or maybe bosch has a built in GPS and will eventually detect the milage differential!
Probably bosch has included bigger chain rings or smaller in the tampering software. So the cadence can be out a few rotations with speed
How safe is tuning nowadays? My commute involves many long, flat sections where I can reach speeds of around 40 km/h. Are error codes more likely to occur when riding at a faster pace?
I experienced a relationship between speed and pedal torque…
Hi - just reading this thread and noticed you have a Bosch Smart System with software version 12.13.0 and have managed to avoid errors with a VolSpeed. How many miles have you done now, and what kind of rides (distance, speed, etc)? I fitted a SpeedBox 1.1 to my 12.13.0 smart system and got an error after ~70mls despite following all of SpeedBox's advice, so looking for any better alternatives.
I've done 700 miles
. Normally between 17 - 21 mph depends on the winds sometimes push it to 25
If you have a rotor magnet, the answer is 100% Speedi. You won't get the top speed of a chip but for off road you don't need it
Had chips before, Speedi is just so much better, a simple , undetectable mechanical device that you can remove in 2 minutes
I live in a very windy city doing 20 in headwind is not nice.
If I was commuting I'd probs be going full speed but I bike for fun.
Its nice setting speed
Like I said, Speedi for off road. Agree for road higher top speed would be better, just don't get caught or run anyone over!
Hay All. I'm just trying to catch-up on the Gen 4 Smart system de resisting info.
Something that are not complelty clear to me today on a valve magnet setup as there is a lot of history here.
Right now what is the best solution for wheel mounted mag models on the valve ?
IV seen Speedbox and Bikespeed , IV seen a lot of past issues with the Speed box but is that still the case ?
With regards to errors I have seen some people have them but are total lockouts still a thing ?
With these lockouts is it only dealers that can remove thes?
Is there risk of permanent lockouts ?
Thanks in advance for any information given.
Can’t say it, but they are able to do whatever they want, we don’t OWN the motor, we just have a licence to use it, even thought we bought it🤬
    Join 43,154
