Dado
- Jun 28, 2022
- 1,035
- 659
What do u think, should be that seal unevenly like that?Okey. Next question. Is this part supposed to be like this? Feels like some kind of seal. It's unevenly in.
Just take the circlip off remove the seal behind it, check that’s not damaged, grease the inner lips, out outer and push it on using a socket, make sure it stays straight.
you should be able to get a replacement seal from any good local bearing supplier.
I was thinking the same thing, I’m quite impressed at the facility actually. Makes you wonder though, how in the world was the original M560 ever released into the wild when they have a dedicated acoustic testing room like that???A motor noise testing room!
Thanks for the updates - more than the noise I think the lack of overheating on a big climb is the best news. I’ll take slight noise for good power and reliability (I always ride with music on anyway). If the M560 does end up taking off at the same rate as the M600 did I expect someone will make a plastic gear for it eventually. If the M600 with the Ludi controller was able to work with it I see no reason why the 750w stock power would be too much for one.
Take M560 if you ok with sound.Exactly what my thinking is... Still have m600 ludi that i can put back but M560 is handling what I have thrown at it so far... So no complaints!
Yes, it work's fine on 48V firmware. 70x LG M58 1502Wh battery is used.Here is 52V firmware. Have not tried yet though.
Anybody tried 48V 750W with 52V battery? That must be sweet.![]()
Dado, do you have latest 750w 1.5 firmware? hearing its has bit more improvements....Here is 52V firmware. Have not tried yet though.
@_gregor does your motor sound the same as this?Take M560 if you ok with sound.
It is a sweetspot in power - 1250W and it is not overheating as much as M600, which is great. Also pedalling is fine and power distribution. Finally some controller user-configurable power settings. (UART has many many more
There is throttle locked to 45kmh. Which is annoying if you used to ride fast.
If somebody would like have throttle limit removal tool, let me know. If I should go to another design and developement.
Also could be useful for M510 FC2.0 - here is throttle limited to 32kmh.
Yep, the same sound.@_gregor does your motor sound the same as this?
About the same as previous onceYes, v1.5 seems legit.![]()
Is this compatible with the 500w controller?About the same as previous onceDidn't notice much...
You may be seeing a mix of old and new, there’s a bad YouTube video of M560 sound which was prior to the updated version. Consensus seem to be that it’s on the louder side but not vastly different than many other moderate sounding motors.WIll it be possible to reduce the noise with grease or will they make different model with one being more silent with different material ?
The current videos around shows it's insanely loud it's crazy
An unloaded bench video isn’t indicative of the motor under load in real world conditions, but yeah, it sucks it’s not just quiet like it should be. It’s not at all an update to the M620, that’s their big heavy motor meant for higher output power, it’s slated to be the new M600 essentially. There is a new M620 in the works as well though, I forgot the exact number on it.I mean the video in the previous page with the update is just awful. It's pretty crazy how worst it sound than the m620 when its supposedly an update no ?
ok yeah i meant it more that a new model should capitalize and not regressAn unloaded bench video isn’t indicative of the motor under load in real world conditions, but yeah, it sucks it’s not just quiet like it should be. It’s not at all an update to the M620, that’s their big heavy motor meant for higher output power, it’s slated to be the new M600 essentially. There is a new M620 in the works as well though, I forgot the exact number on it.
It’s the M630, seems like they announced it and it then fell off the radar for a while, likely had some delays in the final production process or something.ok yeah i meant it more that a new model should capitalize and not regress
what's the new m620?
Nobody knows. It would be nice if they did, but it’ll likely be some 3rd party that does it before Bafang themselves seeing as they literally just released this revised version and it’s still all metal.Will they make the m560 with nylon gear like some of the others motor ?
On which fb group ?Watching some of the videos on the Facebook group
I was in the “Bafang M500, M510, M560, M600, and M820 Users Group” one. If you search for M560 you can see a handful of posts, there are some videos from a guy named Gary Fuller in a few of the comments where he shows his bike being ridden and it sounds pretty manageable. Still hope we get a plastic gear made for it by someone though.On which fb group ?
Hello Azure.@Dado posted somewhere on fb video from downhill ride on bicycle with M560... it is incredible loud motor.
