Marin Alpine Trail E1/2 thread
I have a second battery for my E1. Marin sell spare battery covers as well but you’ll need to get four M4x12mm countersunk bolts. Works out well as most of my riding passes by my car at some point.
So carrying a water bottle? How you all doing it?
I went with the bottle adapter from cycle solvers and the specialised side loading cage and I THOUGHT all was good, but the bottle (500ml) scrapes the underside of the top tube and in addition the piggyback on the DHX2 hits the bottle on compression and has worn a hole in the bottle.
I have now removed the adapter and am just using the bottle and side loader cage but the shock still hits the bottom of the bottle.
Any better solutions or is it time to go back to a backpack or hip pack?
I'm riding a large frame. The bottom of the water bottle was just catching the top of the shock so would probably wear through eventually. So I just taped a spacer to the bottom of the bottle cage - the bottle now sits a couple of mm higher and clears the shock OK.
Any thoughts on the new version - First Look: The 2025 Marin Alpine Trail E Has a Bosch Motor & More Adjustability - Pinkbike
I weighed my large E2 yesterday, running 29" wheels front and rear running Maxxix DD tyres. Came in at 25.8kg. Claimed weight of the new one (admittedly with cushcore installed) is 27.8kg - can't help thinking this is a step in the wrong direction.
Also - ugly! That motor looks huge - has a bit of the Levo 'pregnant seahorse' thing going on. Haven't really paid much attention to Bosch motors, but are they all like this, or is this just a 5 year old cheap one they've stuffed in there?
I personally love the new bike…..finally a 4 bar suspension. There is no mistaking it for an e bike, I am guessing it looks that way for battery removal.
Did your older one not have cushcore? My 2023 E2 has cushcore
Agreed its now an ugly bike thanks to that Bosch
Anyone here tackled rear brake swap? I have an E1, and am throwing on some Code RSC, but just got to the point where I realize the hose is routed to come in behind a portion of the motor. When I push it in it just hangs up behind where the battery plugs in. Would really love to not have to remove the motor, but is that the only way? What a friggin headache if so.
Bless my transition spire with its external rear brake routing.
Okay, figured out a trick in the process that helped a ton, and I now have Code RSC on the bike:
Pushing the hose rear to front, when you put it in the frame near the motor it wants to get pushed into the back of the housing where the female battery connection sits. There's two small bolts holding that on. Remove those, then gently pull it up. At first it felt like it only was going to come up 1 cm or so, but gently pulling on it for a minute, the wires loosened nicely (nothing came undone or aggressively pulled on) and gave me enough room to get my finger in there and push the hose up over the top of that housing.
With that trick I'd say it's as easy as any internally routed MTB I've done. Without that trick it felt virtually impossible unless you thought ahead and used the trick connecting an old hose when you pull out the old brake, as someone outlined in this thread a while back. Hope this helps someone down the road.
Just about to start to put a longer dropper in my E2 anyone know the size of the EP801 motor mounting bolts? I'd like to undo a couple to make the process easier i.e. to open up access to the cable housing. Are the mounting bolts hex or Torx?
Edit: 6mm Hex seems to be the one
Has anyone tried changing the rocker bearings? I'm not quite sure how to get the bearing out as there's a plastic / cheap metal spacer on the 'blind' side (outside) of the bearing. I'd use a blind bearing puller, but the other side of the rocker is in the way as the bearings need to come out in the direction of the arrow. I suppose I could just press the spacer which will in turn press the bearing, but the spacer doesn't seem that it'll be strong enough. Any Ideas?
Just stripped my suspension down and when the extractor and press kits turn up I’ll be doing exactly what you’ve mentioned, I’m also concerned that those spacers look a bit fragile and hope that pressing them out won’t destroy them🤞🏻
Out of interest, what extractor and press kit did you go for - I had a look but couldn't work out what I needed, so was just going to use the stud / washer / socket ghetto version.
And I'll be interested to hear how you go with getting those bearings out.
Hi mate, I went with the RRP Bearing Press Kits 7 and 11. They’re a bit pricey but I’ll likely be doing the job again(defo won’t be leaving it nearly 2 years again!) so I don’t mind, plus I’ve got 2 mates with E2’s who’ll be needing to do theirs sooner than later especially as we bought our bikes within months of each other!
I didn’t buy the actual RRP press cos it was nearly £70, nicely made but I can do the same job with a piece of M8 all thread and a couple of nuts and washers! Haven’t had time to do the job yet but should have it done this weekend.
Is the upper and lower headset bearing race and balls or sealed cartridge? If cartridge does anyone know the bearing codes? Quite some creaking out of mine today, need to pull the fork out and investigate
They're sealed - although you can always remove the seal with a pick, clean and regrease
.But whilst the bearings might need replacing, I often have to remove the fork and re-grease everything - the bearings are fine, but there's lots of interfaces in there which can dry up and cause creaks.
2022 E1 On / Off switch battery
It dies, so after winter storage I can not turn on the bike until it is replaced.
It apparently is a small (button type?) battery according to my local shop.
This happened in my 2024 start up, when I stored the bike w/out the (running) battery installed on the bike.
The shop replaced the dead battery
I left the running battery installed & kept it charged up this year but have the same problem.
Taking it back to the shop today.
Has anyone else had this problem?
Millions of people all over facebook have this problem, I see the question asked daily.
Two solutions I read are [note i have not tried either]
1. Cable tie crank arm to chain ring and spin backwards multiple times, then go for a ride and it will charge from the main battery
2. Charge the main battery, switch on and keep it on do not let it switch off/time out until it has taken a charge from the main battery
Good luck
My dealer says that while in storage you not only have to keep the running battery installed.
You also have to power on the bike every couple of weeks during storage.
The bike stays on for 10 minutes, and during those 10 minutes the on off / switch battery is being charged from the running battery.
Dealers have access to an "E-TUBE-PROJECT" (MS Windows) app that allows it to charge up the on/off switch battery.
The dealer has to open up the (side) motor pod access panel to gain access to the wire going up to the on/off switch.
On the Marin, to gain access to that wire my dealer says he has to drop the motor because of the way the wire is routed on the alpine trail E1.
I found a manual (Shimano Steps Special Battery and Parts) that says that charging the running battery while on the bike simultaneously charges the on/off switch battery but only during the time the running battery is actively being charged.....
This didn't work on my bike. But over the ~ 6 months the bike was in winter storage I only was charging 3 times, and only for abt. 20 - 30 minutes each time. Maybe that was not enuf time. The manual says that charging the on/off switch battery takes 2 hours.
The manual does say that if you have access to the running battery switch, you can use it to turn on the bike..
.. but of course for the Alpine Trail this switch can not be accessed while the running battery is on the bike.
Rumor says that riding the bike will charge the on / off switch battery (i.e., if the crank is being turned the switch battery will be charging). The manual does not mention this. This is a gamble I choose not to take.
For the time being the bike is in the shop, waiting in line.
Charlie
Can any of you confirm if the outer gear housing runs all the way from the shifter to the mech as one continous length of housing?
Should there be a threaded cap of some sort on the circled side of the chainstay pivot? The opposite side says torque to 7Nm but what does it screw in to. I think I might have a threaded cap gone walkies whilst out riding.
    Join 43,246
