Try this. Came straight off my phone with a stock standard ETube appThank you for your reply.
It's possible for you to share files of those old fw version please?
This is not STRide related question. Anyway, STUnlocker informs you which settings are not default and you HAVE TO change all settings back to default/stock before visiting dealer/shop center.Hi Vadll,
Do you know how the "Regulation change history" for a DU-EP800 works?
I had a user report with a red warning.
Then after reseting to default settings its no longer marked red but there is a timestamp for a regulation change.
Is this all the information the DU stores, that a change has taken place only, or dose it store more information?
Right, my mistake. I just jumped into an active conversation with you in it. Should have been more active in choosing the right thread.This is not STRide related question. Anyway, STUnlocker informs you which settings are not default and you HAVE TO change all settings back to default/stock before visiting dealer/shop center.
See my previous post...Still, do you have any knowledge about what happens on the Shimano side of things and how permanent/visible they will be?
I understand that the full accountability lies with me as a user, i am not questioning that and i understand your apprehensive reaction to my question. I am in no way waving my own total responsibility for using the software. I am only here asking for information that you may or may not possess about how shimano's "Regulation change history" works. Call it academy curiosity i you will![]()
How soon will wheel Circumference changes be available with the ep6 and ep801 motors?EP801/EP6 overall Torque/Power settings are now adjustable in then new 1.18 version
So it's possible to make EP801/EP6 RS into the full power motor via Bluetooth
Does changing the wheel circumference settings to a "smaller" size allow the ability to increase the max speed?How soon will wheel Circumference changes be available with the ep6 and ep801 motors?
That is correct!Does changing the wheel circumference settings to a "smaller" size allow the ability to increase the max speed?
yes, as the normal EP8. For Bluetooth you need downgrade to 4.0.2 for the speed derestriction and then update to the actual firmware. With PCE interface the downgrade is not required.Can a EP8-RS be derestricted via bluetooth? Or can this only be done via the pc interface? Also does the motor need to be on a specific firmware version to be derestricted? thx
Sorry, what do you mnean by "then update to the actual firmware"? I used stunlocker with an ep8 on a different bike. That time I just downgraded the firmware and have never updated the firmware since.yes, as the normal EP8. For Bluetooth you need downgrade to 4.0.2 for the speed derestriction and then update to the actual firmware. With PCE interface the downgrade is not required.
Why? The downgrade instruction tells that you have to update to the actual firmware, because 4.0.2 is too old and has many issues.Sorry, what do you mnean by "then update to the actual firmware"? I used stunlocker with an ep8 on a different bike. That time I just downgraded the firmware and have never updated the firmware since.
Yes, exactlyWith the EP8-RS, do I downgrade the firmware, edit the cirfumference/region,etc.. and then afterwards upgrade the firmware?
Yes. To any, including the latestWhen upgrading do I use e-tube? or upgrade back to a specific version?
No. 4.0.2 does not have PW/TQ settings. This firmware does not even know about RS version. 4.0.2 is required for the changing settings via Bluetooth only.Also if I downgrade the motor firmware I could still edit the power/assist levels on the ep8-rs, right?
Ok, thank you so much. I wasn't aware that updating the firmware still allowed you to keep the modified speed settings in place.Why? The downgrade instruction tells that you have to update to the actual firmware, because 4.0.2 is too old and has many issues.
Yes, exactly
I have PCE cable so I can change Shimano EP800 RS to full power 85Nm directly???yes, as the normal EP8. For Bluetooth you need downgrade to 4.0.2 for the speed derestriction and then update to the actual firmware. With PCE interface the downgrade is not required.
Yes, that is correct. You can also do it via bluetooth as well. The advantage of the PCE cable is that to cvhange this setting you do not need to first downgrade the firmware.I have PCE cable so I can change Shimano EP800 RS to full power 85Nm directly???
Many thanks for your reply. I tried root explorer and this worked perfectly.Any should work. You just need to enable access in the settings. Normally the app (file explorer) will pop up a notification and ask you to change the settings. I use root explorer
YesI have a 2021 orbea rise with a doggie ew en100 and not a didplay. Can I still use stunlocker to derestrict the motor to get 85nm? (Btw-I enjoy st ride and so don’t need/want a display)
Please send a link to where I would figure that out for a Mac IOS.
